Author Topic: DVD burning  (Read 3784 times)
Offline greenking
DVD burning
« on: February 10, 2004, 20:34 »
I'm trying to back up some DVD's but although they are ripped and nero says the burning is sucessful there is nothing on the disc  :(
Cammy may have hit the nail on the head as my DVD re writer burns at 8x but no discs are about yet that seems to burn at these speeds  :-\
Can anyone tell me how to get nero or my drive to burn at lesser speeds  :)
Or if this isnt the problem point me in the right direction  :P
Re:DVD burning
« Reply #1 on: February 10, 2004, 20:37 »
What version of Nero do you have GK
Offline greenking
Re:DVD burning
« Reply #2 on: February 10, 2004, 20:40 »
Nero 6  ;D
Re:DVD burning
« Reply #3 on: February 10, 2004, 20:43 »
You should be able to adjust the write speed in this screen (see below), GK, if that's the problem.   The only other thing I can think of is that the source disc is copy protected.   :-\
Offline greenking
Re:DVD burning
« Reply #4 on: February 11, 2004, 01:48 »
Is that using nero Simon, i dont get the option to derermine the speed although  the screen is the same  :-\
The disc source is definately decrypted to my HD
Re:DVD burning
« Reply #5 on: February 11, 2004, 07:48 »
Yes, that's Nero 6.  I have to say, I've not actually used Nero for DVDs.  Obviously, there is alternative software available for burning DVDs, but we're a bit limited as to what can be discussed here.   :-\
Re:DVD burning
« Reply #6 on: February 11, 2004, 12:36 »
Minus 1 Simon for not helping on Forum  ;D
Re:DVD burning
« Reply #7 on: February 11, 2004, 13:57 »
Well, I've hopefully helped him 'off forum'.   ;)
Offline greenking
Re:DVD burning
« Reply #8 on: February 11, 2004, 18:05 »
I've just successfully burned my first DVD  8)
Once i got nero to burn at 2.4x   everything went fine  :)
 :thanks: for your help Simon  ;) but i got away without in the end  :)
And a big  :thanks: to Sandra and Camstop, good work as always  8)
