Author Topic: DVD labelling  (Read 4549 times)
DVD labelling
« on: February 10, 2004, 22:31 »
How does everyone label their DVD's?  At the moment I am just using a magic marker but that looks really scruffy.  Can you buy proper labels which can be used with some sort of software and print them out in colour?
Re:DVD labelling
« Reply #1 on: February 10, 2004, 22:39 »
I mostly use a CD pen myself Clive, but when a bit of quality is required I use PressIT CD labels (from EBuyer) with a PressIT applicator.
Up until recently I was using the CD Label creator in Roxio Easy CD Creator, but I assume there is equivalent software in Nero too.
Short of that Microsof Word will allow passable labels to be designed.
Re:DVD labelling
« Reply #2 on: February 10, 2004, 22:42 »
There are several labelling kits you can buy, Clive.  I happen to use Fellowes CD / DVD Labels, which are available in kits, or just labels, from Dixons / Currys / PC World.  The kit costs £19.99, including labels and PC software.
Re:DVD labelling
« Reply #3 on: February 10, 2004, 22:54 »
Thanks for those tips guys.  I've just looked in the Viking catalogue and found the system Simon is referring to and it costs £19.99 there too.   ;D
Re:DVD labelling
« Reply #4 on: February 10, 2004, 23:17 »
Make sure that you print the label before you stick it on your DVD Clive, as they dont half make a noise as you send your DVD through the printer  ;D ;D ;D
Re:DVD labelling
« Reply #5 on: February 10, 2004, 23:23 »
When we have another run of CD labels at work I will save some for you  ;). Probably in about 3 weeks time.
Hookstar
Re:DVD labelling
« Reply #6 on: February 10, 2004, 23:36 »
Good tip!   :thumb:
Re:DVD labelling
« Reply #7 on: March 23, 2004, 19:00 »
I bought one of the Fellowes Mediaface packages and must say that I'm very impressed with it.  It's very easy to use and the DVD labels look quite professional.  Another success story!
Re:DVD labelling
« Reply #8 on: March 23, 2004, 19:13 »
Yeah I got one of those Clive, am well chuffed. we actually make those labels at work, have enough at home now so will hopefuly never run out  ;)
Offline greenking
Re:DVD labelling
« Reply #9 on: March 23, 2004, 19:25 »
And how many spare ones do WE have Hook
Re:DVD labelling
« Reply #10 on: March 23, 2004, 19:28 »
They are still in a brown envelope waiting for you GK  ;D I did leave them once, but I think it was on one of your Sabbaticals  ;)
