Author Topic: Boot Problem  (Read 1225 times)
Offline renshaw8
Boot Problem
« on: February 11, 2004, 20:13 »
After having trouble starting my pc, I looked around and found in one log a message that said (Failure Code 0016) and in Dr. Watson the message said (ATMSYS.DRV has altered win system files). Can anyone tell me what this might mean and what to do. I deleted some files just before this and I think I might have deleted something I shouldn't have. Thanks
f you watch the penny's, the dollars will watch themselfs.
Re:Boot Problem
« Reply #1 on: February 11, 2004, 20:27 »
Hi renshaw8
 :welcome:
Can you tell us which OS you are using please  ???
Re:Boot Problem
« Reply #2 on: February 11, 2004, 20:53 »
ATMSYS.DRV is something to do with Adobe TypeManager, I think. So I would guess the operating system is Windows 95 or 98.
Not sure what the problem is, but I would guess that re-installing TypeManager should cure the problem.
Online Simon
Re:Boot Problem
« Reply #3 on: February 11, 2004, 21:01 »
System File Checker, perhaps?
Re:Boot Problem
« Reply #4 on: February 11, 2004, 21:08 »
Probably, as long as renshaw8 is running Win98 or above.
Offline renshaw8
Re:Boot Problem
« Reply #5 on: February 11, 2004, 22:12 »
I'm using Windows ME
Offline renshaw8
boot problem
« Reply #6 on: February 12, 2004, 21:31 »
After having trouble starting my pc, I looked around and found in bootlog a message that said (Failure Code 0016) and in Dr. Watson the message said (ATMSYS.DRV has altered win system files). Can anyone tell me what this might mean and what to do. I deleted some files just before this and I think I might have deleted something I shouldn't have. I'm using Windows ME. Thanks
Re:Boot Problem
« Reply #7 on: February 12, 2004, 21:40 »
Hi Renshaw, I brought your post back in with the original one  :)
I cant find anything out about the code that its saying, or the ATMSYS.DRV file  :(
Do you have Adobe Type Manager on your pc ?
If so have you tried reinstalling it as Adept suggested.
The only other thing I can suggest is doing a system restore to a date prior to you deleting the files that you think may have caused the problem, assuming that you can get into either safe mode or normal windows successfully  ???
Offline renshaw8
Re:Boot Problem
« Reply #8 on: February 14, 2004, 18:54 »
Thanks everybody, I appreciate your help. I searched for adobe type manager but didn't find a file or folder named that. I restored my computer back and when it finished, it had renamed a couple of files. SWIMPORT - XTACACHE
