Author Topic: Win XP Filmstrip mode in My Pictures  (Read 1117 times)
Offline thegallery
« on: February 11, 2004, 21:18 »
My Win XP used to have a selection in My Pictures to view the contents as a "filmstrip". I can do: thumbnails, tiles, icons, list, or details, but filmstip is now missing. Any ideas? Thanks.
Re:Win XP Filmstrip mode in My Pictures
« Reply #1 on: February 11, 2004, 21:48 »
View as slide show is part of Picture Tasks.  Is it fully expanded?  If not try clicking on it.
Offline thegallery
« Reply #2 on: February 11, 2004, 22:04 »
Filmstrip views a strip of your pictures in the folder at the bottom and zooms into them up above. It is just another way of viewing your picture images in the folder, with the option available in the view menu. It is not the same as slideshow. But I did what you said, and I figured out how to turn on "picture tasks" back on by customizing the folder, and now the "FilmStip" option is back. Thanks very much.
« Reply #3 on: February 11, 2004, 22:34 »
Best take a lie down, Clive!   ;) ;D ;D
Offline measter
« Reply #4 on: February 12, 2004, 00:11 »
the folders gotta be set for a picture album. right click on an empty space in teh folder, select customize this folder, then select picture album in the pull down menu. ;D
Current CPU Info
Offline Michelle
    • Techieminx
« Reply #5 on: February 12, 2004, 13:06 »
I can't do that in ME then ?  ???
« Reply #6 on: February 12, 2004, 13:52 »
I can view my pictures in the pictures folder under My documents, Michelle, without actually opening the files, if that's any help to you.  :)
