Author Topic: help get my other pc on the net  (Read 3858 times)
Offline Natalie
« on: February 12, 2004, 19:05 »
:-\ please help iam trying to get my sons pc connected, i have a laptopxp which is connected via a access point to my set top box, with a wireless pc card, however my sons pc is windows me and i have connected that one via a USB net adapter. It is showing there is a connection with 100% link and 100% signal however i still cant sign onto the net. PLEASE HELP
Re:help get my other pc on the net
« Reply #1 on: February 12, 2004, 19:24 »
Hi Natalie, and
Don't panic!  ;D  I'm sure one of our techies will be able to help you soon.   :)
« Reply #2 on: February 12, 2004, 19:45 »
Hi Natalie.  Someone will help you sort out your problem very soon.  There are two very competant techies around at the moment and I've alerted another one for you as well.  I can assure you that you are not being ignored.
« Reply #3 on: February 12, 2004, 20:30 »
Hi Natalie, can the laptop and the PC see each other in VIEW WORKGROUP COMPUTERS ?
Offline Natalie
« Reply #4 on: February 14, 2004, 13:30 »
do u mean r they in the same  room,
« Reply #5 on: February 14, 2004, 13:44 »
No I dont Natalie.
If you go to Start/My Network Places then select View Workgroup Computers on your XP PC, does it show both computers in there ?
If it doesnt then the network is definately not set up correctly  :(
If it does show them both then its a case of finding out the settings to enable it to work properly  :)
Offline Natalie
« Reply #6 on: February 14, 2004, 13:49 »
no it only shows the xp laptop not the desktop
« Reply #7 on: February 14, 2004, 14:00 »
Ok, can you explain a little more about the method that you are using to connect the pcs together with please ?
You say its a usb network adaptor, is that usb to usb or usb from one pc to an ethernet cable adaptor then ethernet cable to the other pc?
Offline Natalie
« Reply #8 on: February 14, 2004, 14:13 »
i have a access point conected to the digi tv and a wireless pc card in the laptop, then i bought a usb network adapter to go in the desktop which is upstairs in my sons bedroom
« Reply #9 on: February 14, 2004, 14:18 »
Its this usb network adaptor that I would like some information on Natalie, can you tell me the make and model then I can find out a little more about how its supposed to work ?
Offline Natalie
« Reply #10 on: February 14, 2004, 14:24 »
its belkin usb network adapter model no F5D6050.
« Reply #11 on: February 14, 2004, 14:30 »
Ok, give me a few minutes to see if I can find some information about it Natalie and I will get back to you.
I have one of those but not sure if its the same model number so we may be in with a good chance of sorting it out  :)
Offline Natalie
« Reply #12 on: February 14, 2004, 14:35 »
Excellent, thanks for your help, cause im at the end of my tether with it
« Reply #13 on: February 14, 2004, 14:42 »
Ok its a bit different to mine but I think it works the same way  :)
If anyone is seeing this and can offer any input, this is Natalies device :
http://www.lanshop.co.uk/f5d6050.htm
Have you run the installation CD on your sons PC Natalie ?
Usually You have to have the usb cable disconnected when you install the software then connect the cable when it asks you to do so  :)
Offline Natalie
« Reply #14 on: February 14, 2004, 14:45 »
yes i have done that and it is showing fully connected however when trying to connect it shows as the web page being unavailable
