Author Topic: files location  (Read 1620 times)
Offline measter
files location
« on: February 14, 2004, 06:57 »
well, to be honest i have no idea where this would go ???
anyway, does anyone know how to move a files physical location on a hard drive? cause i'v got a bunch of files at the end of my hard driver that i need to move to partition the drive.
Current CPU Info
Re:files location
« Reply #1 on: February 14, 2004, 09:58 »
Not sure if I understand the question -- can you not just cut and paste or drag and drop?
Re:files location
« Reply #2 on: February 14, 2004, 10:34 »
First of all defragment your drive a couple of times. This will consildate your files and reset the free space list.
Then copy (not move) the files you need to move to another (temporary) folder. Make sure the files have copied correctly.
You can then delete the original files.
Then move the copied files back to the original folder.
The files will now be in a different physical postion on the hdd. But of course there is no guarantee as to where they will go :)
Offline Robotochan
Re:files location
« Reply #3 on: February 14, 2004, 10:37 »
I think he means that the files he is talking about are on the outskirts of the Hard Drive Disk therefore they take longer to find etc.
Have you tried Perfect Disk? It's a defragger that moves all your used files to the middle of the disc and all the files you don't use much to the edges. Which I've tried and there is a smaller seek time  :)
b]Oxymoron: [/b]
Example:
Microsoft Works
Re:files location
« Reply #4 on: February 14, 2004, 20:45 »
No Robo, what Measter means is that he has some files at the end of his drive which are preventing him from being able to use partition manager software such as Partion Magic to split one partition into two.
Your Perfect Disk solution is correct though :D ;)
Offline measter
Re:files location
« Reply #5 on: February 14, 2004, 21:16 »
this my problem
all i know is that there are some files there. i have no idea what files they are.
Current CPU Info
Re:files location
« Reply #6 on: February 14, 2004, 23:25 »
I would guess that they are your Swap file.  Occassionally (but not very often) I delete mine, by starting my computer at the c:\ prompt and typing
del c:\windows\win386.swp
Then switch of at the power, switch back on and the Swap file will rebuild itself.
A word of caution, it is not recommended to delete the Swap file.  Having said that, it has never caused me any problems.
Offline lobo
    • http://www.burnleywood.com
Re:files location
« Reply #7 on: February 15, 2004, 00:56 »
@Measter
Windows system writes files to certain locations the hard drive and are not movable but they are generally at the beginning of the drive. It could be the swap file/virtual memory or just a file in use by a program
Partition magic should be able to create a new partition as it works in DOS without windows being loaded
Brian  :)
Homer   , The Odyssey, line 1
Offline measter
Re:files location
« Reply #8 on: February 15, 2004, 11:06 »
what i'v decided to do is backup anything i want to keep, then partition the drive then see if anythings wrong. if something is wrong then i'll just format and reinstall windows.
Current CPU Info
Offline measter
Re:files location
« Reply #9 on: February 16, 2004, 01:45 »
just so ya'll know, i'v resized the partition wiht only i minor problem. which was those files at teh end of the drive, which as far as i can tell were only drivers for some hardware. which windows pomptly sorted out.
Current CPU Info
Offline lobo
Re:files location
« Reply #10 on: February 16, 2004, 08:58 »
@Measter
Always nice to see members working in a systematical way to a solution
Well done Measter
Brian :D
Offline measter
Re:files location
« Reply #11 on: February 16, 2004, 09:08 »
why thank you ;D
anyway, i'm now downloading linux to install in the unformatted space. it's 3 650 - 700 mb files. so that'd be around 9 hours of total downloading, and i'v done 2 of the files. just another 5 - 6 hours and i'll probably be posting on here from within linux on my favorite browser(firefox). ;D
Current CPU Info
Offline lobo
Re:files location
« Reply #12 on: February 16, 2004, 20:04 »
@Measter
Linux likes to be installed on the root of C: just make sure you know what you are doing when you install of you could loose a
everything
Brian
Offline measter
Re:files location
« Reply #13 on: February 17, 2004, 04:59 »
actually, mandrake linux will install on the unpartitioned space if you want it to :P
i'm currently on linux now, though i have no idea whatsoever how to install something, so i'm stuck with mozilla 1.4 instead of firefox. :-\ i like the fuzzy clock ;D
oh yeah, sorry i missed my deadline of 5 - 6 hours, i fell asleep :snooze:
Current CPU Info
Re:files location
« Reply #14 on: February 17, 2004, 10:14 »
Good lad Measter,
trying something new...forever pushing the bounderies of your knowledge, is like accumalating wealth
