Author Topic: Unofficial Windows 98 SE Service Pack 1.1  (Read 944 times)
« on: February 15, 2004, 22:49 »
Major Geeks
Microsoft has never released a service pack for Windows98 SE. But I made a Service Pack for Windows98 SE users. It contains all Windows98 SE updates from WindowsUpdate site and more.
It is a self-extracting and self-installing pack like Microsoft's update files. Thus, you cannot choice files individually. Uninstallation is possible from Add-Remove Programs. Beta 2 users should install this pack without uninstalling the pack.
IT IS ONLY FOR WINDOWS 98 SECOND EDITION ENGLISH. It contains only operating system updates. It does not contain DirectX, Media Player or other similar products
Features:
- 52 hot fixes. (All of them are from Microsoft's WindowsUpdate.)
- 256-color tray. (Some icons on the tray like WinAMP's icon will be shown better.)
- Better Defrag. (Faster. It is from Windows ME. However, It works properly on the Windows98 SE.)
- Better Notepad. (Same Notepad with more key bindings.)
- Optimized swap file usage. (Windows will not to use the swap file at all until all of the RAM is used.)
- Better WDM/USB support. (Most problems about WDM drivers and USB devices are solved.)
- Windows Scripting Host 5.6. (It is latest version of Scripting Host which also contains VBScript and JScript support.)
- Visual Basic 6.0 SP5 runtime library. (To run Visual Basic 6.0 programs.)
- Windows2000 color scheme. (You should select it from Control Panel-Display-Apperance.)
- A few performance tweaks.
 http://tinyurl.com/33rsf
