Author Topic: Help wanted  (Read 4926 times)
Help wanted
« on: February 17, 2004, 12:43 »
Only me with a small request, can someone with BB down load the latest Drivers from Here and put them on a disc and post them onto me  ;D if some one would be so nice, I would be willing to pay for post and packaging etc.
If they would I will PM them my address.
The reason I want them is that if I downloaded them on my 56k it would take a month of sundays  :-\
Hookstar
Re:Help wanted
« Reply #1 on: February 17, 2004, 13:38 »
The drivers are only 71K Hooky  ???
Or do you mean the application :
Latest WinFast PVR with Power-up scheduling (S3/S4) & Channel Surf support provides you the most feature-rich video/audio entertainment.
Use Hot Key "F6" for Channel Surf function.
(Note: Please install driver before installing WinFast PVR.)
Total size:[18665 KB]
I see that it has a split file option for that one for people on 56k
Re:Help wanted
« Reply #2 on: February 17, 2004, 14:48 »
As Sandra said, the drivers themselves are only 71Kb, so that shouldn't be too much of a problem for you Hook.  If it's the larger download of the actual application you want, I'll be happy to do it for you.   :)
Re:Help wanted
« Reply #3 on: February 17, 2004, 17:23 »
I already have the Drivers its the Winfast PVR that I need, even with the 4 down loads it would still take over 60 mins :(.
Simon I have This if you want to do a straight swap ;)
Hookstar
Re:Help wanted
« Reply #4 on: February 17, 2004, 17:44 »
Ok Its been resolved, I have had a PM  ;) cheers anyway  ;D
Re:Help wanted
« Reply #5 on: February 17, 2004, 17:51 »
Thanks Hook, I already have LXG, but I wouldn't have wanted anything in exchange.   :)
Re:Help wanted
« Reply #6 on: February 17, 2004, 19:33 »
Ok folks its all sorted now, I have found out that I dont need the extra bits... Just thought it might boost the performance of the Winfast but have since found out it won't make a jot of difference, let sleeping dogs lie and if it aint broke dont fix it etc etc  ;D
Hookstar
Re:Help wanted
« Reply #7 on: February 17, 2004, 19:45 »
That was a stroke of luck, Hook!   ;)
Re:Help wanted
« Reply #8 on: February 17, 2004, 20:23 »
it was was'nt it  ;D
Re:Help wanted
« Reply #9 on: February 17, 2004, 20:41 »
I didnt find the wind up at all funny, Im about to sign off now for good bye all  >:(
Offline Serenity
Re:Help wanted
« Reply #10 on: February 17, 2004, 22:47 »
 :yawn:  how many times has he said this  ::)  ;D
Re:Help wanted
« Reply #11 on: February 17, 2004, 23:05 »
Hooky I know you will do some lurking, if it?s only to see if we are talking about you ;)
So come on, you of all people should be able to take a joke???.least ways  no one wrote terrible things about you, like they did about me......and I?ll have you know nearly half of those untruths written about me, were made up ::) ;)
Re:Help wanted
« Reply #12 on: February 17, 2004, 23:14 »
:pmsl:  Tony, he gone away to plot his revenge!   ;)
Re:Help wanted
« Reply #13 on: February 17, 2004, 23:16 »
Beverly Serenity you know me so well :d even tho you know my every movements on here  :-X
And Tony, being an ex Landlord when I left you should know that between 9 and 11 is the best time  ;)
He he
Re:Help wanted
« Reply #14 on: February 17, 2004, 23:31 »
You mean to tell me, you had me an Sandra downloading at 6Kb  while  you were out drinking  ;)You do pick some crap sites for downloading from   :-\
