Author Topic: image size  (Read 2017 times)
Offline computer_whizz
    • http://www.geocities.com/makz_tabs
image size
« on: February 18, 2004, 15:52 »
Ive made a site using HTML but when i put my images in they are way too big! how do i resize images? im using a mac
 may be left handed but im always right
Re:image size
« Reply #1 on: February 18, 2004, 18:10 »
Which web editor/creator prog did you use ?
I think I can resize in the one I use and then just overwrite the original HTML  ???
I must admit I havent used it much though so I am not like your namesake with HTML ;)
Re:image size
« Reply #2 on: February 18, 2004, 18:12 »
Don't know the first thing about Macs, I'm afraid.  Do you have any inage editing software, like Paint Shop Pro, or Adobe?  I'm sure you could resize images using one of those.  Please come back to us if you need further help, and one of our more technical people should be able to assist.   :)
Re:image size
« Reply #3 on: February 18, 2004, 19:14 »
Image editing software will reduce the image size, but you can do it manually if you want, viewing the web page in HTML. But if you reduce the height by 10% than you must reduce the width by the same percentage. The editing software will of course alter both height and width, when you alter either one by default.
Welcome Whizz
