Author Topic: Weather Watcher  (Read 9811 times)
Weather Watcher
« on: February 19, 2004, 16:55 »
Neat little utility which sits in your system tray and tells you what's happening outside in your locality.
http://www.singerscreations.com/
Re:Weather Watcher
« Reply #1 on: February 19, 2004, 18:06 »
Oi!!  What are you doing using Internet Explorer??!!   >:( >:( ;)
Re:Weather Watcher
« Reply #2 on: February 19, 2004, 18:32 »
Clive thats brilliant  ;D Does it tell you that its going to snow this week end  ;)
Re:Weather Watcher
« Reply #3 on: February 19, 2004, 18:33 »
:aarrgh:  Big Brother is watching!   ;D  I must set it up to default to Mozilla as I know it makes sense.   ;D
Re:Weather Watcher
« Reply #4 on: February 19, 2004, 18:35 »
I've clicked more checkboxes now so that to gives me additional information and I think it updates once a minute.  41F here now.   ;D
Re:Weather Watcher
« Reply #5 on: February 19, 2004, 20:33 »
Wouldn't it be easier to just look out of the window Clive ;D ;D
Re:Weather Watcher
« Reply #6 on: February 19, 2004, 20:36 »
Cant you just send Gladys, your favourite sheep, out for a few minutes and feel at her fleece when she comes back in ?
That way you would find out if its wet or dry and if theres snow on it youd know that it was snowing  ;D ;D ;D
Re:Weather Watcher
« Reply #7 on: February 19, 2004, 20:55 »
I've installed it!  :sadgit:  3° here at the moment.   ;D
Offline Michelle
    • Techieminx
Re:Weather Watcher
« Reply #8 on: February 19, 2004, 21:30 »
ohhh I'm gonna get that too, does it give you wind speed?
  ;D  ;)
Offline Michelle
    • Techieminx
Re:Weather Watcher
« Reply #9 on: February 19, 2004, 21:58 »
Am so impressed thats great  :D
Re:Weather Watcher
« Reply #10 on: February 19, 2004, 21:59 »
Look out of the window????  We aren't allowed to have windows here Adept!   ;D
Wind speed is 16 mph right now Michelle.   It will convert to kilometres if you want.  ;D
Re:Weather Watcher
« Reply #11 on: February 19, 2004, 23:49 »
It's excellent isn't it!  I'm going to recommend this to all my friends!   ;D ;D
Re:Weather Watcher
« Reply #12 on: February 20, 2004, 07:34 »
Or sharp objects apparently ::) ;D
Offline Serenity
Re:Weather Watcher
« Reply #13 on: February 20, 2004, 08:12 »
  ;D  ;)
Depends what time you had your Curry the night before  ;D
I'm sad too Ive installed it  ;)  :P
Offline Camstop
Re:Weather Watcher
« Reply #14 on: February 20, 2004, 08:57 »
So is this worth ditching "Weather pulse" for, that you got us to install a few weeks ago then Clive  ::)
