Author Topic: Found some Software ?  (Read 815 times)
« on: February 22, 2004, 18:01 »
Hi All, doing some clean up work on the puter just now and was looking in the Add/remove program and came across one I didnt reconise.
Its called Answerworks, I have attached a screen hunter clip, does anybody know what this is, is it something to do with a cad program that my daughter has added to the system? bearing in mind its not very big something like 0.1mb
Have googled it >>> http://www.wextech.com/support.html
hookstar
Offline ketamininja
Re:Found some Software ?
« Reply #1 on: February 25, 2004, 13:33 »
Since its just a runtime program, that is why its so small.
It should be safe to remove it, its like a bolt on for the main Answerworks client side program.
