Author Topic: Ntl  (Read 5974 times)
Offline Whiskas
Ntl
« on: December 30, 2002, 20:47 »
Does anyone on here use ntl as their isp? I've heard that you can get a good deal on your telephone, tv and internet through them. To be honest I quite sick of Sky and BT so if anyone can tell me what they're like it would be much appreciated.
Re:Ntl
« Reply #1 on: December 30, 2002, 21:06 »
I have heard mixed reports about NTL, but they do offer some good all-in-one packages.  Why don't you check out some of THESE COMMENTS on ISPr, Whiskers?  It might be some help, at least from the ISP prospective.   :)
Re:Ntl
« Reply #2 on: December 30, 2002, 21:07 »
I have a few friends use it for broadband and are delighted with the price/service Whiskas. I dont know anyone who just has 56K on it but as Rodders will confirm,their half BB service seems to be exceptionally good value  :-*
Re:Ntl
« Reply #3 on: December 30, 2002, 21:08 »
I have a number of customers who use NTL broadband connections Whiskas. They don't appear to have very many problems with the service that NTL provides.
Apparently the technical support isn't too responsive, but that could be said about almost any ISP these days.
Re:Ntl
« Reply #4 on: December 30, 2002, 21:12 »
Ntl cable BB rocks!  Just do it, Whiskas!   :)
Offline Whiskas
Re:Ntl
« Reply #5 on: December 30, 2002, 21:12 »
I believe they install the covetted Broadband free of charge.
Thanks for that Simon I'll check it out  ;D
Yes my friend did say that it can take a while to get through to customer services but when you do they are very helpful.
Re:Ntl
« Reply #6 on: December 30, 2002, 21:20 »
Start here, Whiskas.   ;)
The £50 start-up is only waived during promotions, but you might be lucky -- I was!   :)
Offline Whiskas
Re:Ntl
« Reply #7 on: December 30, 2002, 21:21 »
I just had a look on ISPr but someone has mentioned that if you have a visible telephone line you can't get it :'(
Offline Serenity
Re:Ntl
« Reply #8 on: December 30, 2002, 21:24 »
Whiskers, I am with NTL and also have Boadband. I have nothing but praise and the charge is just £16.50 per month which I am led to believe is exceptionally cheap in comparison to other ISP's  :o so I would highly recommend this an an option
Re:Ntl
« Reply #9 on: December 30, 2002, 21:29 »
What little extras are you getting for that then, Serenity?  They're only charging me £14.99 pcm.  For that I get 128kb BB, which actually works at 256kb because I'm in an ex-Cable & Wireless franchised area.   ;D
Re:Ntl
« Reply #10 on: December 30, 2002, 23:28 »
whiskas, i would definitely recommend ntl broadband. 128k is £14.99 a month, 600k £24.99, 1 meg £34.99. i've got the 600k and i would never go back to dialup.
i didnt know that the 128k runs at 256k in ex c&w areas, as rodders says, sounds too good to last for long (til ntl realise).
i'm sure that if you pushed them you'd at least get free installation.
Offline Serenity
Re:Ntl
« Reply #11 on: December 31, 2002, 15:18 »
Well Rodders, I've got 512kb and of course with BB am "always on"  ;) Bit like a Nun's Knickers!  :o  ;D
Re:Ntl
« Reply #12 on: December 31, 2002, 15:24 »
...Bit like a Nun's Knickers!  :o  ;D
Obviously something I'll need to look into, Serenity.   ;D
Re:Ntl
« Reply #13 on: December 31, 2002, 16:28 »
Don't start us all off Serenity!!   ;D   Imagination plays a big part at my age.   ;D  ;D
Offline bat69
Re:Ntl
« Reply #14 on: December 31, 2002, 17:04 »
You're bragging again CLive  ;)
