Author Topic: Can't play games because..  (Read 1203 times)
Offline Beany
« on: February 27, 2004, 05:27 »
I keep getting this error message appear whenever I quit the game and sometimes whilst I'm playing. From this error message my only option is to reset the machine.
Take a look
http://meshybeats.com/beany/pictures/error/error02.jpg
If anyone can help me it would make my life just that little more stress free.
Thx
Re:Can't play games because..
« Reply #1 on: February 27, 2004, 07:14 »
Hi Beany :welcome:
CMUDA.SYS is causing the problem. It is a driver for a C-MEDIA sound chip.
Possibly, installing the latest drivers will cure problem. If the drivers from your sound card (or motherboard) manufacturer's site do not cure the problem, there may be some certified drivers available from Microsoft which will work.
HTH
Offline Beany
« Reply #2 on: February 27, 2004, 13:22 »
Yeeha.
Thanks Adept. After some searching I found a driver and I installed it and so far it seems to be working.
This problem had me riled up quite a lot for ages.
Cheers
Beant
Offline Beany
« Reply #3 on: February 27, 2004, 15:57 »
Gyaaa it still does it.
Man this is the most annoying problem I've ever had.
Offline ketamininja
« Reply #4 on: February 27, 2004, 16:43 »
Try going to your MAINBOARD manufacturers website.
Look in the DRIVERS section for your particular mainboard model number.
Download the new audio drivers there. These ones should work perfectly.
However, it is possible that you have a memory issue of some kind. Everytime the audio is making a reference in memory, this is where it is falling over. Now it could be that the drivers are referencing the memory incorrectly (hence new drivers should fix) or it could be that a certain area in memory that is commonly used by those (correct) drivers is bad.
If you can, do a search for DocMemory, a free memory tester.
Offline lobo
    • http://www.burnleywood.com
« Reply #5 on: February 27, 2004, 23:00 »
Homer   , The Odyssey, line 1
