July 03, 2024, 06:20
Technical Help & Discussion
Pretty fans
Topic: Pretty fans (Read 1596 times)
bat69
Loyal Member
Pretty fans
December 31, 2002, 14:20 »
Simon, you said you wanted lights
HERE
is a little article on blue LED fans, they're easy to install / replace original ones and they do make a boring case a little different.
I've got a multi colour one in the top of the case and will have a blue one on the side, when I put the window in 8).
Re:Pretty fans
December 31, 2002, 16:28 »
Yeah, cool looking kit! Trouble is, my PC is stuffed under a desk, so any pretty lights would be hard to spot, unless they're on the front! I like your front panel display!
bat69
Loyal Member
Re:Pretty fans
December 31, 2002, 16:42 »
Thanks Simon
But hey ... have Dremmel, will make holes >
I cut 3 extra holes in this case, ok two were already perforated (but that is a restriction to airflow) and another BIG hole is planned >
Pretty fans
