Author Topic: AVG Update  (Read 1681 times)
AVG Update
« on: March 02, 2004, 19:57 »
Anybody else using AVG.. the update tonight took ages (13 mins) plus it took ages to connect  :o
Re:AVG Update
« Reply #1 on: March 02, 2004, 20:17 »
Same here Hook. I think they must be having server problems :(
Re:AVG Update
« Reply #2 on: March 02, 2004, 20:22 »
I wonder if they have a virus  :D
Re:AVG Update
« Reply #3 on: March 02, 2004, 20:27 »
If anyone else is having problems, the US website seems OK.
Download the updates manually from http://www.grisoft.com/us/us_updt6.php?lng=fe
and put them in the \programs files\Grisoft\AVG6\Updates folder :)
Re:AVG Update
« Reply #4 on: March 02, 2004, 22:50 »
I updated last night without any problem.
Virus database 383.
Release date 01/03/04.
Approx size of download 75KB.
Offline Michelle
    • Techieminx
Re:AVG Update
« Reply #5 on: March 06, 2004, 14:58 »
Yeah it is being a bit odd lately - I tried 2 or 3 times to pick one up yesterday or day before was it.
It had done it now though.
Re:AVG Update
« Reply #6 on: March 11, 2004, 17:32 »
Ok I was still having trouble (anybody else) but I have found a cure, anybody interested  ;)  ;D saw it on another forum but it works a treat 1st time every time  8)
Hookstar   :P
When you restart AVG you'll have three choices to download from instead of the default one.
Edit: Thought I would just add this  :D
Re:AVG Update
« Reply #7 on: March 11, 2004, 19:04 »
I'm a bit thick today Hookster ::) what exactly do you mean? I've closed the AVG Control Center and restarted it, but I still only get free.grisoft.com as the download choice  :-\
Re:AVG Update
« Reply #8 on: March 11, 2004, 19:08 »
Save your old file as url.old and create a new file in notepad with this:
[SERVER_NAME]
1=free.grisoft.cz
2=ftp.grisoft.com
3=www.grisoft.com
[SERVER_URL]
1=http://free.grisoft.cz/softw/60/fe
2=ftp.grisoft.com/pub/softw/60/fe/
3=http://www.grisoft.com/softw/60/fe/
Actual URL=3
Re:AVG Update
« Reply #9 on: March 11, 2004, 19:16 »
Ah - I thought something was missing ::)
The file that needs to be changed is url.ini which is kept in the \programs files\grisoft\avg6\ folder
