Author Topic: PCI Graphics Card  (Read 1523 times)
PCI Graphics Card
« on: March 02, 2004, 21:19 »
I have (another!) friend who wants me to upgrade her PC Graphics.  She has a Time / Tiny pile of which doesn't have an AGP slot   ::)  so can anyone recommend a good PCI Graphics Card?  She was going to get a GeForce Ti4200 128Mb 8X AGP for about £80, but that option is now out of the question.  I was thinking of this one, from Dabs.  Any opinions welcome.   :)
Re:PCI Graphics Card
« Reply #1 on: March 02, 2004, 23:59 »
Seems par for the course price wise Simon, just one question, prob showing my ignorance. But I notice it say's DVI, will the video signal output socket be the standared 15pin D plug or whatever they are called , or is it a digital plug connection?
« Reply #2 on: March 03, 2004, 08:29 »
Dunno mate.  ???  Could someone check that out, please, before I order the wrong thing?   :)
Offline ketamininja
« Reply #3 on: March 03, 2004, 12:49 »
Most DVI-only outputs come with a DVI/vga convertor/dongle. Check that. Otherwise they can be bought for about a fiver if you look in the right areas.
« Reply #4 on: March 03, 2004, 14:49 »
I don't want to complicate things with Dongles, can anyone confirm if this card is DVI Only?
« Reply #5 on: March 03, 2004, 15:02 »
Its only an adaptor Simon, nothing complicated to it  :)
« Reply #6 on: March 03, 2004, 18:23 »
I think I'm going to go for  this one instead.
« Reply #7 on: March 04, 2004, 20:50 »
outta stock Mate  ;D
« Reply #8 on: March 04, 2004, 20:56 »
Well, it says 1-3 days, and I don't need it till next week anyway.  If they don't ship it by Monday, I'll look elsewhere, but that was the best price I found for that card.
Offline Valleyscarlet
« Reply #9 on: March 08, 2004, 02:58 »
I have the same problem with Time/Tiny and the only graphics card on a PCI I would choose is a Geforce FX5200 128MB which is around £52.00 on E-bay, Don't know whether that's any help?? :)
.Thomas
« Reply #10 on: March 08, 2004, 07:39 »
Thanks Valleyscarlet, and
That's the card I have on order with Dabs, so good to hear a recommendation.   :)
Offline princeofdarkness
« Reply #11 on: April 15, 2004, 12:40 »
seems a good graphics card  ;)
shame your friend cant get agp one though  :(
quot;Spirits damned to rot
Eyes of the dead
Broken glass reflections
Show your flesh eaten away
