Author Topic: msn 9  (Read 810 times)
msn 9
« on: March 02, 2004, 23:30 »
have a friend with msn 9 and he wants to move his favorites to his internet explorer. Ive looked around and found this
http://www.mainsoft.fr/freeware_en.htm
not sure how exactly this adds into things but i found it nonetheless after a google search. Look at the bottom of the list to see the freeware relating to this problem. If any of yall have come across the same problem and have something to share it would be appreciated
Re:msn 9
« Reply #1 on: March 02, 2004, 23:39 »
Looks like it does what it says on the tin, Bob.  You use the program to convert the MSN Favorites to a bookmark.htm, then Import them into IE.  If it works, it couldn't be simpler!  I haven't tried it myself, but I have imported Favorites into IE from Mozilla in the same way, and it works fine.
Re:msn 9
« Reply #2 on: March 03, 2004, 00:29 »
yea i red that much, i haven't used it before either. So i thought i might send it by my fellow foreign computer nerd friends before i installed it into use. Thanks for the look over simons :)
