Author Topic: DvD Shrink 3.16  (Read 6048 times)
DvD Shrink 3.16
« on: March 03, 2004, 17:41 »
The above is the dogs Boll The above version seems to be working very well as it reconises nero and there is no need to copy files as it seems to just get on with it, it even asks you to put a dvd in the drawer  ;D and is mostly automatic.
Before you say anything  8) its for backing up purpoises  ;D
Offline greenking
Re:DvD Shrink 3.16
« Reply #1 on: March 03, 2004, 18:09 »
3.1 will do the same, but copying to your HD first allows you to adjust settings in nero  ;)
Re:DvD Shrink 3.16
« Reply #2 on: March 03, 2004, 18:31 »
Are purpoises like tortoises?   :P ;D ;D
Re:DvD Shrink 3.16
« Reply #3 on: March 03, 2004, 19:20 »
Noooo Simon Purpoises glide like my dvd back up with 3.16   ;)
Offline Delgado
Re:DvD Shrink 3.16
« Reply #4 on: March 17, 2004, 08:00 »
Cant seem to understand this. Does this work on converted AVI files or is it only for DVDs that you are copying? If you download a film and convert it to DVD format on your hard drive to burn and its too big does this do it? I tried and it didnt pick up any files.
 :help:
Re:DvD Shrink 3.16
« Reply #5 on: March 17, 2004, 12:32 »
Delgado look Here for some info  ;)
Offline Delgado
Re:DvD Shrink 3.16
« Reply #6 on: March 17, 2004, 18:00 »
Thanks Hookstar- Looks an interesting page
     :welldone:
Re:DvD Shrink 3.16
« Reply #7 on: March 17, 2004, 18:05 »
That helped me loads Delgado, hope it helps you  ;) I have just this min backed up Underworld and The Italian Job.
Hookstar
Offline greenking
Re:DvD Shrink 3.16
« Reply #8 on: March 17, 2004, 18:08 »
Hookstar
If you would like me to have a look at your backed up copy...just to make sure its ok from a neutral point of view Hook,   I'd be more than happy to  ;)
Re:DvD Shrink 3.16
« Reply #9 on: March 17, 2004, 18:11 »
GK   see the footie thread, I will have them in my Pocket  ;)
Re:DvD Shrink 3.16
« Reply #10 on: March 17, 2004, 18:13 »
Of course, that is for your own private use, from a source you personally own, Hook.  I know you meant to say that.    ;) 8)
Re:DvD Shrink 3.16
« Reply #11 on: March 17, 2004, 18:19 »
Hookstar
Re:DvD Shrink 3.16
« Reply #12 on: March 17, 2004, 18:35 »
Can anyone here point me in the right direction for a cheap source of eye patches, peg legs and parrots? ::) ;)
Re:DvD Shrink 3.16
« Reply #13 on: March 17, 2004, 18:40 »
GK that reminds me..I have Pirates of the Carabean as well  ;D
Re:DvD Shrink 3.16
« Reply #14 on: March 17, 2004, 20:45 »
Hookstar, this is a hint - thread closed :(
