Author Topic: Space Problem  (Read 740 times)
Offline pbk
  • New Registration
Space Problem
« on: March 03, 2004, 23:02 »
Recently I deleted Linux OS from one of the partitions by using fdisk. Right now my PC is only having windows 98. The Hard drive is having 20GB of free space, But the C drive is having only 10GB.
How do I add 20GB to C drive?
Re:Space Problem
« Reply #1 on: March 03, 2004, 23:47 »
Hi PBK, and
One of our techies will be along shortly to look at your problem.   :)
Re:Space Problem
« Reply #2 on: March 04, 2004, 05:37 »
well you could make a second Fat32 partrician using the extra space. If i remember right it would just show up as another drive letter. Then if you wanted to merge you could use partrician magic, thats if you have partrician magic.
ALWAYS backup your important data when using partrician magic or screwing with your particians at all.
