I have just bought a pc but it keeps crashing/rebooting/freezing when I play games. It has happened with loads of games and downloading patches does not help. Please help me to get it to work!
It is an AMD Athlon 2500 overclocked to be Athlon 3200, 1GB DDR400 RAM, AsRock K7s8xe motherboard, GeForce 5200 128mb graphics card, 160GB hard drive.
Once you turn the computer on the games will play for about 15 mins before crashing but after that it keeps crashing very quickly. There is a big fan inside and everything seems to be staying cool apart from the graphics card which is getting extremely hot. But even when I replaced the GeForce with a state of the art Radeon with massive fan, it still crashed. It did not make it through to the end of 3Dmark (graphics testing program) with either card.
The motherboard manual says that it supports only 1 slot of DDR400 RAM but I have been supplied with two but taking one out does not solve the problem. Also the RAM is running at less than 1GB per second which seems odd. Could the overclocking be causing the problems?
I am clueless as to how it can be fixed. Maybe I should get a refund for it but I only paid £450 for it which seems quite good value for money. Thanks
