Author Topic: empty windows  (Read 9614 times)
Re:empty windows
« Reply #15 on: November 06, 2002, 01:04 »
Hes tried that Lona but it wont as he has a later version of IE on it and it wont let him  ???
Re:empty windows
« Reply #16 on: November 06, 2002, 01:08 »
That's weird Sandra. I have used system restore since I downloaded IE6 and it worked. Sometimes it is disabled at startup and you have to goto msconfig to put it back.
Offline Barra
Re:empty windows
« Reply #17 on: November 06, 2002, 02:29 »
SORTED!!!!
 Found ie5.setup.exe on Ddrive. When I used that instead of version on CD, it let me overwrite all but one of the files in boldprint.
Learning more and more with each passing day! ::)
Re:empty windows
« Reply #18 on: November 06, 2002, 02:32 »
Well its about time Barra a hell of a lot of days have passed now  ;D ;D ;D
Re:empty windows
« Reply #19 on: November 06, 2002, 08:05 »
Don't you just love success stories?   ;D  ;D  ;D
Offline Barra
Re:empty windows
« Reply #20 on: November 06, 2002, 10:37 »
! down and one to go. Still not fully sorted mt IDE controller proble, and I'm sure theres plenty more marching over the hill. :o
Offline bat69
Re:empty windows
« Reply #21 on: November 06, 2002, 10:48 »
Its amazing how these silly problems make you so determined to sort them. They make you so angry and annoyed, and determined not to be beaten by them. Well that's how it works for me, but then there's always the hammer ;)
Re:empty windows
« Reply #22 on: November 06, 2002, 13:04 »
Can anyone explain why,if it was an IE fault,the stuff on drive D worked ok  ???
Shouldnt an IE problem affecting the boot drive also have a similar efect on the second drive  :-";"xx
Re:empty windows
« Reply #23 on: November 06, 2002, 14:38 »
Could it be that IE is a separate installation on D: Drive?
Offline bat69
Re:empty windows
« Reply #24 on: November 06, 2002, 14:43 »
Well I've found IE defies all logic when it comes to creating problems, I've had so many problems with IE and Explorer, and something that seems detached from the problem solves it. Either that or I'm fik ::)
Re:empty windows
« Reply #25 on: November 06, 2002, 16:26 »
Do you think maybe it's IE that's causing all my cutoff problems  ??? ??? ???
Offline Barra
Re:empty windows
« Reply #26 on: November 06, 2002, 16:58 »
NOPE! :)
