Hi Scotty_CFC
![welcome :welcome:](http://www.pc-pals.com/smf/Smileys/Smileys/welcome.gif)
Can you see the make and model number, including revision number if possible.
If you can tell us which one it is we should be able to tell you where to get the drivers for it.
The drivers maybe different depending on which OS you are using too, so if you let us know that as well please.
Is it showing the yellow ? in Device Manager next to the multimedia part or not displaying it at all in there
![Huh? ???](http://www.pc-pals.com/smf/Smileys/Smileys/huh.gif)
XP is usually quite good at finding the drivers by itself, providing that the onboard sound is enabled in the bios
