Author Topic: Picture copying  (Read 3297 times)
Picture copying
« on: January 01, 2003, 17:08 »
My neice send me copies of family pictures in an email. The problem is she did not enclose them as a file and must have copied and pasted them directly onto the email. My problem is when I try to copy and paste only the picture I can't. It will only copy the complete email and I tried saving as an jpg file but when I try to open the file it can't be read. Some of the pictures are in the centre of the email and I can't move them on a word doc. Anyone got an answer? ???
Offline bat69
Re:Picture copying
« Reply #1 on: January 01, 2003, 17:12 »
Have you got PaintShop Pro Lona?  as you can cut out the pics and save them using that program
Re:Picture copying
« Reply #2 on: January 01, 2003, 17:13 »
Not wishing to teach granny to suck eggs, but have you actually tried tracking the outline across the top of the picture with your mouse, Lona?  You should be able to separate the pic from the text without too much trouble.  Otherwise, perhaps copy the whole thing into something like Paint Shop Pro (or even just Paint), and try to separate it.
I'll have another think and come back to you after tea.   :)
Re:Picture copying
« Reply #3 on: January 01, 2003, 17:17 »
Lona does it show uo as anything when you right click on an individual picture? ie do you get a box with properties at the bottom?
That should tell you what they are sent as.
If there isnt anything personal in it or if you can delete the text,feel free to send it to me and I will see if I can extract them for you  :-*
Re:Picture copying
« Reply #4 on: January 01, 2003, 17:20 »
I've tried everything I can think of Sandra but it won't let me just copy and paste the picture.
I will send you a copy of the email right away. :)
Re:Picture copying
« Reply #5 on: January 01, 2003, 17:36 »
Ok Lona its on its way back to you  ;)
I just right clicked and it let me save it,maybe Incredimail allows it whereas OE wont  ???
Offline DualBoy
    • http://www.pingme.ca
Re:Picture copying
« Reply #6 on: January 01, 2003, 19:46 »
Did you right click on the image and choose "save picture as"? then Save it to your local drive someplace. Then import it into any image program or such that you prefer. I like Photoshop 6 (Dont like 7 too much) and for printing images I would recommend ACDsee.
Re:Picture copying
« Reply #7 on: January 01, 2003, 19:54 »
Thanks all for your help. Didn't think of simply right clicking on picture and saving it as jpg. Sometimes its the obvious we overlook. :-[
Offline DualBoy
Re:Picture copying
« Reply #8 on: January 01, 2003, 20:00 »
Been doing tech support for years. The simplest answer is usually the one thats right.  :)
Re:Picture copying
« Reply #9 on: January 01, 2003, 20:20 »
It's great to have another techy on board DualBoy. A belated welcome to the forum from me :)
That's so right! Occam's Razor is a handy tool  ;) ;D
