Author Topic: CD Writer  (Read 4317 times)
CD Writer
« on: March 11, 2004, 00:39 »
My cd-writer is acting up and I'm not sure what's wrong. It will burn a few discs then it just stops recognising that there is a disc in the drawer. The disc is always very hot when I remove it. If I shut down and wait half an hour, then reboot, writer works ok. What could be causing this?
Re:CD Writer
« Reply #1 on: March 11, 2004, 00:48 »
Sounds like overworked caused by excessive downloads since you got BB Lona  ;)
Re:CD Writer
« Reply #2 on: March 11, 2004, 00:50 »
 :wahh: :wahh: :wahh: :wahh: :wahh: :wahh:
Re:CD Writer
« Reply #3 on: March 11, 2004, 07:11 »
Sounds like it could be overheating Lona  :-\
Re:CD Writer
« Reply #4 on: March 11, 2004, 07:43 »
I found that when CDs start coming out extra warm (they are usually warmish after burning), the drive is usually on the way out.   :(
Offline Dogsbody
Re:CD Writer
« Reply #5 on: March 11, 2004, 08:11 »
As Simon says Lona it sounds as though its on the way out I had one which did what yours is doing and it finally died. Now buried in the back garden next to the old monitor that succumbed as well. :-\
Re:CD Writer
« Reply #6 on: March 11, 2004, 11:32 »
Lona,
Does the drive also disappear in "My Computer"? That happened to me on a PC running ME, installed W2K, same thing. Also, when you put a CD in the drive, the PC locked up. It was only a bog standard CD-Rom, I then installed my CR-RW 32x12x24 in to that PC, problem solved.
So I sold that drive for a tenner, and bought a nice new shiny fast Samsung Drive 52x32x52, £26.95 with carrage includes Nero V5.5 software.
http://www.cclcomputers.biz/acatalog/
Go on treat yourself, as it sounds to me like your writer is on the way out.
Re:CD Writer
« Reply #7 on: March 12, 2004, 01:52 »
Tony
My drive doesn't disappear from my computer but when I click on the drive with a disc in drawer it says "insert disc" but not every time. As regards buying a new writer, would such a fast one be compatible with my P111, 1ghz speed PC?
Re:CD Writer
« Reply #8 on: March 12, 2004, 07:56 »
I don't think that would be a problem, Lona.   :)
Re:CD Writer
« Reply #9 on: March 12, 2004, 14:09 »
Lona,
new writer will be OK on your system, is the writer as old as the PC ? have you tried reinstalling the writer software? I'm just of the opinon, when kit like that acts up, and taking into consideration it's age and it's speed. For ball park £26 you can save yourself alot of hassle, and have a fast writer to boot.
Re:CD Writer
« Reply #10 on: March 12, 2004, 16:46 »
Yes, writer came pre-installed with PC. I was just looking at that site, Tony and I think I should be going the full hog and buying the dvd writer and cd writer combined. Would I be asking to much of my machine or would I still be ok.?
I see they have a Sony,
Sony DW14A Silver (Dual Writer +/-) OEM Ref: CDR4027
Silver OEM Drive - (4x DVD+R / 4x DVD+RW / 4x DVD-R / 2x DVD-RW / 24x CD-R / 16X CD-RW), (OEM DVD Drives require DVD playback software)
In Stock(As Of 17:30 On 11/03/2004)
Online Price  £61.60£72.38 Including VAT
What do you think?
Offline ketamininja
Re:CD Writer
« Reply #11 on: March 12, 2004, 18:31 »
Its always handy I suppose, but will you really be burning DVD's??
£40 could buy you something else  ;D
Re:CD Writer
« Reply #12 on: March 12, 2004, 19:18 »
Re:CD Writer
« Reply #13 on: March 12, 2004, 20:06 »
Re:CD Writer
« Reply #14 on: March 12, 2004, 20:08 »
DVD's hold lots more data, Ketamininja. If I have to replace might as well buy dvd writer as I would probably want one at a later date anyway.
