Author Topic: Ashampoo Win Optimizer  (Read 874 times)
Offline Delgado
« on: March 14, 2004, 09:16 »
  I dont know if anyone here is using this-but be wary of it! I downloaded a trial version, and wouldnt recommend it. It is supposed to be foolproof if you use it on the default setting. It stripped out a load of files from my Outlook, resulting in me running a repair.
I dont like it at all. If you want a good programme of this type try System Mechanic 4, far superior.
     :damn:
Offline Dogsbody
Re:Ashampoo Win Optimizer
« Reply #1 on: March 14, 2004, 09:27 »
Thats strange I've been using it for months , got it off a PC Answers disc, never had any probs at all. Sweet as a nut I,ve found.
DB ???
Offline Delgado
« Reply #2 on: March 14, 2004, 16:47 »
DB ???
 Fair enough. just goes to show that what suits one PC dosent suit another. Maybe its because Ive got a copy of Outlook 2003 with (cough)   extended trial!
 :rock:
« Reply #3 on: March 14, 2004, 23:13 »
I have a system full of extended trial software.  When I tried AShampoo, it made such a mess of my system that I ended up doing a format.
Another program to be wary of is RegSupreme.  The bloody thing completely stripped my user.dat file, which is one of the two files that make up the registry in Windows 98SE.  Fortunately, I was able to restart at the C:\ prompt, run Scanreg, and restore the previous day's registry.
Programs like that can  be lethal at times.   >:(
Offline Delgado
« Reply #4 on: March 15, 2004, 07:31 »
Glad to see that Im not the only one! Wont use it again!
