Author Topic: Printing sizes  (Read 803 times)
Printing sizes
« on: March 14, 2004, 18:50 »
Hopefully someone will know the problem to this printing queery as its driving me nutz  >:(
Scanned a picture and set the sizes to 270mm x 183mm saved to file.  easy so far huh  ;D well, when I go to print and using XP it gives me several options on what sheet/photo to print to but its never the size that I saved the picture and I dont seem to be able to find out how to print the correct size  ???
Any help would be greatly appreciated  8)
Offline DJ
Re:Printing sizes
« Reply #1 on: March 14, 2004, 19:38 »
I've noticed this aswell Hook - very annoying isn't it.
You can't (as far as I can see) print in the original size using WinXP's inbuit print wizard. Can't you put the image into Word or open it using an image program and then print?
DJ
Re:Printing sizes
« Reply #2 on: March 14, 2004, 20:07 »
Sure is DJ, I just tried paint but that has just crashed on me  >:( so it look like a reinstal of Paint to get that working now..even more frustrating  :-\
