Author Topic: Printer Problem  (Read 936 times)
Offline BIG_J
Printer Problem
« on: March 16, 2004, 18:59 »
Hey I just got a new printer from my father and it is a Lex-mark x1100 series with the usb hook up and my computer will not install the computer because it says it cannot find the software to complete the installation.  Is there any way that I can find or buy the software to install this printer ??? Thanks in advance PC Pals Rulz!
ith all there is, there is nothing.  Nothingness plagues us everyday.  Everyday nothingness consumes all leaving the void which cannot be filled.  The void, that eternal darkness seeps out from the cracks and devours all the light leaving only nothingness to consume all.  Nothingness is everything
Re:Printer Problem
« Reply #1 on: March 16, 2004, 19:04 »
Hi Big J!
You can get drivers and utilities from  http://www.lexmark.co.uk/  Hope that helps.   :)
Offline BIG_J
Re:Printer Problem
« Reply #2 on: March 16, 2004, 19:12 »
Thanks! I will check it out ;D
Offline DJ
Re:Printer Problem
« Reply #3 on: March 16, 2004, 20:19 »
Hi and :welcome: Big_J,
I recently bought a Lexmark X1160 printer (similar to that above) and it came with 3 installation CD's - did yours not have them?
Slightly off topic - the only thing the printer didn't come with was a power lead - really annoying when you don't have one spare and have to go out and buy one to get things running!  ::)
DJ
