April 07, 2025, 13:12
Technical Help & Discussion
background problem
Topic: background problem (Read 1224 times)
white fly
Regular Member
background problem
March 19, 2004, 16:23 »
the other day i downloaded a pic of the web and somehow it got saved as a background and i cant get rid of it , i have been on properties then onto background , so how do i delete it as an option as a background
Re:background problem
March 19, 2004, 17:18 »
You should be able to find it if you go into Start/settings/control panel/display folder. Double click on the display folder and you should be able to find it in Desktop. Then you can either remove it or change it to something else.
March 19, 2004, 17:49 »
If you mean your desktop wallpaper, then Clive is correct. You can also access it by right clicking an empty area on your desktop, and selecting Properties > Desktop. Another way is simply to find another picture you want as your background, right click it, and choose Set As Desktop Background.
white fly
Regular Member
March 19, 2004, 21:52 »
yes but how do i delete it as option , so i cant have it as a background again
March 19, 2004, 22:00 »
I don't think you can delete any of the ones which came with Windows, but haveyou tried right clicking the new one?
March 19, 2004, 22:32 »
Tha Desktop Backgrounds which come with Windows live in C:\WINDOWS\Web\Wallpaper (well, they do on mine, anyway), but I don't see any need to delete any of them. Like Clive said, why don't you just replace the one you don't want, with one you like?
Lona
Ultimate Member
March 19, 2004, 22:48 »
Quote from: white fly on March 19, 2004, 21:52
You can always select "none" for backround and you don't need to delete any.
Dr. Louis B Wright, Washington DC, National Geographic (1964), from Donald MacDonald, Edinburgh
background problem
