Author Topic: Spybot  (Read 1274 times)
Spybot
« on: March 19, 2004, 20:06 »
Just used spybot and it found 72 varmints on my pc (adaware didnt find any). some of them looked quite serious including several gator applications and numerous altered registry keys.
my questions are
 why the difference between adaware and spybot ?
would zone alarm alert me if any of these things were trying to access the outside world ?
should i trust spybot and remove the miscreants it found     ???
Re:Spybot
« Reply #1 on: March 19, 2004, 20:18 »
Not sure what the real difference is, but Ad Aware and Spybot often find things the other doesn't, hence the advantage of using both.
I have never had any problems letting Spybot remove stuff.  Obviously, if you have programs which rely on Adware / Spyware to run, they won't work if Spybot does it's stuff, but then you're probably better off looking for alternatives anyway.
Not sure about ZA.  It should warn you if a program is attempting to access the internet, but some spyware are just tracking cookies, so ZA won't tell you about everything.
Hope that helps, but a proper techie would probably advise you better.   ;)
Re:Spybot
« Reply #2 on: March 19, 2004, 20:19 »
Dunno
Maybe
Yes
Not sure why these things happen but best to take a belt and braces approach sometimes  :)
Re:Spybot
« Reply #3 on: March 19, 2004, 20:31 »
Sandra, I wish you'd stop being over technical!   ;D ;D
Re:Spybot
« Reply #4 on: March 20, 2004, 00:01 »
Hi, Dave.
Do yourself a favour.  Run AdAware and Spybot a couple of times to remove the nasties, and then install Spyware Blaster.  It stops nasties from ever being installed in the first place.  Since I installed it and first ran it, neither Adaware or Spybot have picked up a single item of spyware.
Hope this helps.  :)
http://www.javacoolsoftware.com/spywareblaster.html
Re:Spybot
« Reply #5 on: March 20, 2004, 00:11 »
Thanks everyone and dave i'll install that   ;)
Re:Spybot
« Reply #6 on: March 20, 2004, 00:24 »
Installed spyware blaster but got runtime error 339
MSCOMCTLOCX or one of its dependencies not correctly registered: a file is missing or invalid   :-\
Re:Spybot
« Reply #7 on: March 20, 2004, 00:59 »
I forgot to mention, It's always missing.  If you scroll to the bottom of the page, the installation file is there.  :)
Re:Spybot
« Reply #8 on: March 20, 2004, 13:10 »
Thanks Dave  ;)
