Author Topic: Is it possible to.....  (Read 3694 times)
Offline Jaminxz
« on: April 01, 2004, 22:16 »
Right it sounded weired to me, so nobody laugh  :-[
But i heard off somebody it's possible to play ps2 on yourpc monitor through a tv out card,is this true??
Also,how do you get tv through a tv out card??
Re:Is it possible to.....
« Reply #1 on: April 01, 2004, 23:16 »
Woudlnt have thought you could do that as how would the PS2 connect to the pc in the first place and what would be the point ?
The TV out is usually to connect your pc to a TV via an S-Vid connector or a comp video connection so you can watch films from dvds etc on your tv screen  :)
Offline ketamininja
« Reply #2 on: April 02, 2004, 18:22 »
The only way it could be done is if you connect the PS2 "composite" connection (yellow RCA jack) to a TV-IN connection on a TV capture card (some gfx cards have it).
What you would be better doing however is downloading a PS/2 EMULATOR and playing the games from the PC instead of through it.
Offline Jaminxz
« Reply #3 on: April 05, 2004, 02:48 »
Do ps2 emulators exist?
If so any ideas where to get a good free version??
also if you wish to view tv on your pc is it possible to get some sort of arialto plug into your pc??
« Reply #4 on: April 05, 2004, 04:29 »
wouldn't you want to play your ps2 on the tv being bigger than your monitor? Why the hell would you want to use your monitor?
But there are tv-in jacks you can get with specific tv cards, and some video cards come with tv-in.
And yes there are ps2 emulators, do a google search.
Offline lobo
    • http://www.burnleywood.com
« Reply #5 on: April 05, 2004, 09:29 »
Homer   , The Odyssey, line 1
Offline Jaminxz
« Reply #6 on: April 06, 2004, 19:11 »
It sounds cheap, but i'm going to uni in september and i don't want to pay for a tv licence and i can't survive without my ps2!!
Offline Jaminxz
« Reply #7 on: April 06, 2004, 21:42 »
I checked the emulator out, it isn't really an emulator,i don't think. If anybody understamds the following, please let me know!!!
PCSX2 - A PS2 EMU
Here it is. A first try for an ps2 emulator...
Of course it isn't very advance now but there are some stuff here...
Overview
Well i will try to catch up some questions.
First of all pcsx2 don't run Ps2 games yet!
And of course it is far from doing this.
So pcsx2 don't run GT3, get it? :)
So what pcsx2 is? pcsx2 is a try to emulate sony's beast.
Of course it isn't so easy as it might seems.
So far you can consider pcsx2 as a develop tool althought
i suggest don't use pcsx2 as a tool for writing your ps2dev
stuff :). Consider the opinion that pcsx2 have bugs and we
wrote this emu by reverse enginnering ps2 demos that might
have bugs too :)
Hope you enjoy pcsx2..
The Pcsx2 team..
Configuration
Cpu Options:
Misc Options:
 * Enable Console Output:
    Displays the psx text output.
 * Enable patches
    Enable the patches for games.(if they exist).
    Might fix some stuff might screw some stuff.
    Enable it at your own risk.
 * Enable pad hack.
    if your pads doesn't seem to work if you enable that much fix the pads for the specific game.
    Warning!! not leave that option checked might broke some other games as well
Recompiler options:
*  Disable Recompiler (default). It will run with interpreter if it is ON.
   Slower but more compatible.
*  Disable Vu recompiler (default). Will disable the vu recompile
  (of course if recompile mode is used). More compatible recompiler but slower.
 * Enable reg caching (disabled in 0.6)
    Enable the reg caching recompiler (you must have enable interpeter cpu off!)
    It is more faster than the default recompiler
Quick Keys:
 F1: Save state
 F2: Change slot (0-5)
 F3: Load State
 F8: Makes a Snapshot
 (debugger keys)
 F11  un/sets Log
 F12 un/sets symbol logging
Status
Most part of ps2 have been emulate.
Things that are still missing or uncomplete
IPU : decoding almost done. Pcsx2 can play *.ipu or *.m2v files but no pss yet
VU  : there are several issues with graphics ingames. Still we are not sure if it is GS, VIF or VU problems
      but we are looking for it
SPU2: no spu2 plugin that works atm.
Pads: most of the times works okay.
Memcards: nasty work since they have some kind of encryption . we are looking for them..
recompiler: planning for fast reg cache core and recompile of vus . Soon :P
and of course a million other bugs that exists and we hope they will be fixed ;0
How you can help
If you have any info you think we can use email us, but always ask before
sending files. If you want to help in some other way also email us.
The Team
Nickname    | Real Name           |   Place   | Occupation        | e-mail               |  Comments
Linuzappz   |                     | Argentina | Main coder        | linuzappz@pcsx.net   | Master of The GS emulation and so many others..
Shadow      | George Moralis      | Greece    | co-coder-webmaster| shadowpcsx2@yahoo.gr | Master of cpu, master of bugs, general coding...
florin      | Florin Sasu         | Romania   | co-coder          | florin@pcsx2.net     | Master of HLE. Master of cd code and bios HLE..
asadr       |                     | Pakistan  | co-coder          |                      | Fixing bugs around (FPU, Interpreter, VUs...)
Goldfinger  |                     | Brazil    | co-coder          |                      | MMI,FPU  and general stuff
Nachnbrenner|                     | Germany   | co-coder          |                      | patch freak :P
ex-coders:
basara     -co-coder  . Recompiler programmer. general coding
[TyRaNiD]  -co-coder  . GS programmer.General coding
Roor       -co-coder  . General coding
Additional coding: F|RES
BETA testers
belmont
parotaku
bositman
CKemu
Raziel
Snake875
Elly
CpUMasteR
Falcon4Ever
Team like to thanks the Follow people
Duke of NAPALM - for the 3d stars demo. The first demo that worked in pcsx2 :)
Tony Saveski (dreamtime) - for his great ps2tutorials!!
F|res     - You will learn more about him soon. but a big thanks from shadow..
Now3d     - The guy that helped me at my first steps..
Keith     - Who believed in us..
Bobbi     - Thorgal: for hosting us, for design or page and some many other
Sjeep     - Help and info
BGnome    - Help testing stuff
Dixon     - Design the new pcsx2 page, and the pcsx2.net domain
bositman  - pcsx2 beta tester :)  (gia sou bositman pare ta credits sou )
No-Reccess- nice guy and great demo coder :)
nsx2 team - for help to vu ;)
razorblade - for the new pcsx2 logo,icon.
snake      - he knows what for :P
ector      - awesome emu :)
zezu       - a good guy. good luck with your emu :P
Credits
Hiryu & Sjeep - for their libcdvd (iso parsing and filesystem driver code)
Sjeep - for SjDATA filesystem driver
F|res - for the original DECI2 implementation
libmpeg2 - for mpeg2 decoding routines
aumatt   - for applying fixes to pcsx2
Microsoft - for vc.net 2003 :p (really faster than vc6) :P
NASM team - for nasm
and probably to a few more..
Special Shadow's thanks go to...
My friends : Dimitris, james, thodoris, thanasis and probably to a few more..
and of course to a lady somewhere out there....
Log off/
Linuzappz/ shadow / florin / asad/  goldfinger / nachbrenner (others???)
Offline lobo
« Reply #8 on: April 06, 2004, 21:49 »
Not me my friend, it looks like double-Dutch ro me
My grandson runs an emulator but is always having trouble and I don't think its worth the trouble, get some PC games you can't beat them
Brian ???
« Reply #9 on: April 07, 2004, 00:00 »
well i guess thats me forgetting im in the US and yall are in the UK. I guess if i had to pay for tv i would be figuring out ways around the rules too.
I thought they could only scan to see if your tv was watching a specific channel, not if it was on at all. I mean if you weren't watching tv or "using the queens radio waves" you would be able to use your tv legally.
Do they make TVs that have been gutted to be used for consoles or strickly for vcrs. I mean take the receiver out or make a attachable receiver card of some sort, i guess im thinking of some sort of monitor with a addon to make it a fully functional tv.
Do yall half to pay to listen to radios?
« Reply #10 on: April 07, 2004, 00:05 »
I think they pick up on the reflected RF from the TV set itself Bob.
Thats how they can tell which channel you are watching as it sends a signal back out, unless you could shield the whole set somehow, maybe by building a faraday cage around it would make it invisible to the detectors  :)
Offline FREEZY
« Reply #11 on: April 07, 2004, 13:06 »
check this site out for PS2 emulators
www.ngemu.com
Offline Jaminxz
« Reply #12 on: April 09, 2004, 19:05 »
well after doing some reaserch on it it seems there are no working Ps2 emulators, not sure on the technics but something to do with the computer having to be 5x the speed of the emulatee.
Offline Jaminxz
« Reply #13 on: April 10, 2004, 19:23 »
back to the tv again, is it possible to get some sort of ariel to plug in??
« Reply #14 on: April 10, 2004, 19:51 »
Do you mean something like this from :
http://www.ardelectronics.com/
Description:   PSX RF ADAPTOR
Product Code:   180-03109
  allows connection to a television with no direct line input through the normal aerial socket
Single Unit Price:   £9.00
5 or More:   £8.50
Special Offer Price:   £5.75
   (plus VAT at 17.5%)
