Author Topic: Deleting Norton systemworks 2001  (Read 1402 times)
Offline themackem
« on: April 09, 2004, 14:35 »
Hi.can anybody advise me?I want to install Sytemworks 2004,but i needto delete the 2001 system first.its not letting me do this.Any ideas?I dont know what to do!Thanx! :D
Re:Deleting Norton systemworks 2001
« Reply #1 on: April 09, 2004, 14:41 »
Hi themackem and :welcome:
Have you tried uninstalling it in safe mode ?
Which OS are you using ?
Most uninstalling problems are caused by the program still running when you atempt to uninstall it.
If you are on XP you can bring up the task manager and end all processes that may be using it or part of it.
Do you get any specific message when you try to uninstall it ?
Offline themackem
« Reply #2 on: April 09, 2004, 14:53 »
Thanx sandra.On add or remove programs,i dont get an option on the uninstall wizard.How do i try and delete in safe mode?
« Reply #3 on: April 09, 2004, 15:02 »
You will probably find that the option isnt there in safe mode either unfortunately  :(
The normal way is to get into safe mode by repeatedly pressing F8 and then when its in safe mode going into Control Panel and then the Add/Remove as you have done in normal windows.
This would have the advantage of the program probably not running in the background allowing it to be removed.
I cant find anything specific to System Works but there is an article here about Norton 2001 :
http://support.microsoft.com/default.aspx?scid=kb;en-us;315336&Product=winxp
I am not sure its the same thing but if its not listed in Add/Remove it sounds as if its corrupted or partially uninstalled in some way.
Was it listed at one point and you thought that it was uninstalling and then it failed or has it never been listed in Add/Remove ?
Maybe try reinstalling it again would allow you to uninstall  ???
Offline themackem
« Reply #4 on: April 09, 2004, 15:09 »
Ive tried re-installing,but it wont uninstall afterwards.It just remains on the add,remove list.Before i reinstalled,it didnt show at all on the add,remove list.Have i wasted my money,having a 2004 disc and being unable to use it?My norton firewall installed no problem!
« Reply #5 on: April 09, 2004, 15:34 »
Reinstall it again and if its then showing on your Add/Remove list in normal windows, try removing it in safe mode as described earlier.
That may be all that it needs, I thought that it had never showed in the list so the safe mode option wouldnt have worked but I am 99% certain that it will do it ok in safe mode  :)
Offline themackem
« Reply #6 on: April 09, 2004, 15:36 »
Ok sandra,ill try that now.
« Reply #7 on: April 09, 2004, 20:19 »
Hate to possibly state the bleeding obvious, and I expect you've tried it, but is there an Uninstall in the Start > All Programs list for it?  Or how about in the actual program folder?  As Sandra said, usually, re-installing these allows you to then remove them.
Offline themackem
« Reply #8 on: April 10, 2004, 16:30 »
Problem solved folks!Ive downloaded a tool from symantec,SYMCLN.EXE.Thanks for your help anyway. :D
« Reply #9 on: April 10, 2004, 18:18 »
Glad you managed to sort it  :)
Did you try removing it in safe mode first or did you find that tool before you tried it ?
Offline themackem
« Reply #10 on: April 10, 2004, 19:50 »
I tried safemode,but that didnt work.I like this site,its great for someone as computer illiterate as me!
« Reply #11 on: April 10, 2004, 19:55 »
Thanks, but its great for people at any level too, we like to think  :)
Everyone has to start somewhere and no matter how much someone knows there is always something new to learn  :-*
