Author Topic: It's up to our forum administrators  (Read 2224 times)
« on: April 11, 2004, 12:24 »
Here's an interesting downlods site.
I don't know if we are permitted to show it on our forum publically. Our forum administrators can see to that:
  http://www.softpedia.com
You can go to the left-side of the site page "Quick Categories", and choose whatever you want.
Enjoy   :)
Re:It's up to our forum administrators
« Reply #1 on: April 11, 2004, 12:50 »
I havent had time to check anything but the front page Joudi but all the downloads on that page appear to be freeware, shareware or demos.
As long as there are no cracked programs listed then I think that it should be ok  :)
Clive will probably head straight for this one  ;)
Porno Crawler 2.0 update  screenshot
This program explores the web and finds porn to download while you're away      :o
Online Simon
« Reply #2 on: April 11, 2004, 15:50 »
Looks OK to me too.  Thanks Joudi!   :)
« Reply #3 on: April 11, 2004, 15:51 »
I've downloaded it Sandra, but I'm still trying to configure it to search for sheep photos.  Any ideas?
Online Simon
« Reply #4 on: April 11, 2004, 16:03 »
Perhaps it needs a Tool Baa, Clive.  :aarrgh:
« Reply #5 on: April 11, 2004, 18:09 »
Not enough Ram .. Simon  :-X
« Reply #6 on: April 11, 2004, 18:43 »
See what you are up against Joudi?  You start off a perfectly good thread and within minutes it's sheepjacked.  ;D
« Reply #7 on: April 11, 2004, 18:46 »
Its ok Clive..we can't pull the WOOL over Joudi's eyes
Online Simon
« Reply #8 on: April 11, 2004, 20:08 »
« Reply #9 on: April 17, 2004, 17:45 »
Ewe lot just can't stick to the point can you  :hatoff:
Offline Dogsbody
« Reply #10 on: April 22, 2004, 16:29 »
It did start off as a mint source though ;D
DB
« Reply #11 on: April 22, 2004, 18:43 »
Absolutely mutton to worry about then!
« Reply #12 on: April 22, 2004, 18:59 »
:aarrgh:
