POD has PM'ed me, and e-mailed me some screenshots of a problem with installing a new graphics card. Here is what he said:
i recently tried installing a graphics card which did not work it came up with a dialog box which i would like to show it you so if i could email you you the screenshots that wud b great.. but also after that a black screen came up wen i was loading the pc up about power and megahertz or sumthing
PoD
note: i have tried reinstalling the card but it didnt work and there seemed to be a power prob as well have you got any idea wat i shud do???
did you get the pics
thanx in advance PoD
The screenshot below is probably the most relevent. The other two were of the other tabs in the box, just saying that the drivers were not installed. The only thing I could suggest was re-installing the drivers from the CD that came with the card, and adjusting the BIOS to see a PCI card, but I didn't comment about the power issue. Does anyone else have any better suggestions?
