Author Topic: floppy problem ?  (Read 998 times)
Offline white fly
floppy problem ?
« on: April 14, 2004, 14:34 »
:hi:   on my pc , not the one im one now , but the one in my room , when i boot up a message comes up sayin'
         your floppy drive is identified incorrectly in system
         setup . run system setup to change configuration , press
         <f1> to continue or <CTRL+ALT+ESC> to enter system setup
now, i'm reletivily new to pc's so im not quite sure whats the matter , however i did previously take off the case and took the floppy drive out but didn't disconnect anything , no cables or anything ??
i know jonah has already given me somthging to try out , but i just wondered if you lot have had any problems of the same kind or if you could help me
  thanks , much appriciated !!  ;)
               WF
Offline DJ
Re:floppy problem ?
« Reply #1 on: April 14, 2004, 14:37 »
You should be able to enter the BIOS screen by hitting F1 on startup and assign the floppy drive correctly.
That way the computer will identify it and all will be well.  :D
HTH
DJ
Offline princeofdarkness
Re:floppy problem ?
« Reply #2 on: April 14, 2004, 14:51 »
yay lol i told WF to change bios  ;)
i got it right next question is for 1 million pounds and will be answered after the break on who wants to be millionaire
Jonah  :P
quot;Spirits damned to rot
Eyes of the dead
Broken glass reflections
Show your flesh eaten away
Re:floppy problem ?
« Reply #3 on: April 14, 2004, 15:45 »
Its possible that you disturbed the end of the cable that connects to the modo without realising it so it may be an idea to open the case and check that all the connectors are pushed fully home  :)
Re:floppy problem ?
« Reply #4 on: April 14, 2004, 16:50 »
it really is my day  ;D i told him that as well
you walk away wiv 1 million pounds
 :P
Eyes of the dead
Offline white fly
Re:floppy problem ?
« Reply #5 on: April 14, 2004, 20:15 »
you lot deserve 10000 million for all the help i get on here , thanks i'll try it out , i can't wait till i get a bit more experiance to help others too ! ;)
Re:floppy problem ?
« Reply #6 on: April 14, 2004, 20:17 »
thats the spirit  ;)
let us know when you get it sorted  ;D
Jonah
Eyes of the dead
