Author Topic: macromedia studio mx  (Read 2485 times)
Offline princeofdarkness
« on: April 15, 2004, 13:50 »
what do you think of macromedia studio mx? i have just got it ;)
dont really know what it does  :(
i just assumed it was good because of the price  ::)
Jonah
quot;Spirits damned to rot
Eyes of the dead
Broken glass reflections
Show your flesh eaten away
Re:macromedia studio mx
« Reply #1 on: April 15, 2004, 14:30 »
Its good but you may find it a little complicated as it has too many options  :(
A simpler and easier program to learn on is Swish  :)
« Reply #2 on: April 15, 2004, 14:39 »
lol the disk didnt work but macromedia flash 2004 works  ;D i cant wait to use it  ;D (what does it do  :-\)
Jonah
Eyes of the dead
« Reply #3 on: April 15, 2004, 14:51 »
Things like my sig on here and other sigs that are on the forum amongst over stuff  :)
« Reply #4 on: April 15, 2004, 15:02 »
wow cool then you can just upload em?
ermmm... is that wat you use?
Eyes of the dead
« Reply #5 on: April 15, 2004, 15:03 »
y does it say global moderator on your sig?
Eyes of the dead
« Reply #6 on: April 15, 2004, 15:15 »
I use Swish but I think most "Flash" programs work in a similar way, its just that I have found Swish to do what I need and havent needed the extra features that macramedia has.
I have recently started using SwishMax which has a few more options than the original Swish did.
That Sig was done a long time ago when I had only just started using Swish and I wasnt an Admin back then and I havent had the time to make a new sig for myself as I have to answer a lot of questions these days  ;)
You may want to look at these as a couple of examples of what even a novice with flash like myself can do :
This one looks better if you reduce the window it opens in to a size about a quarter of the screen.
Place your cursor over the central area of the sig and listen to it then click on the spinning planet on the right side.
Click on the object that replaces the spinning planet to return to the original sig after you have heard the second sound  :)
http://www.sandrataylor.dsl.pipex.com/clive1.swf
This one was my Xmas sig and has 3 different sounds in it, place your cursor over the chimney for sound 1, my name for sound 2 and on merry christmas for sound 3  :)
http://www.sandrataylor.dsl.pipex.com/sandra.swf
« Reply #7 on: April 15, 2004, 15:27 »
lol they are cool  ;)
Eyes of the dead
« Reply #8 on: April 15, 2004, 15:33 »
:'( it wouldnt work on ME? i have xp personally but i would of liked to make sure it worked  :'(
nooooooooooooooooooooooooooooo!!!!     :brick:
Jonah
Eyes of the dead
