Author Topic: tar files?  (Read 1492 times)
Offline princeofdarkness
tar files?
« on: April 15, 2004, 16:07 »
is there a program to open tar files or something? because i have some programs that are tar files..
thanx in advance Jonah
quot;Spirits damned to rot
Eyes of the dead
Broken glass reflections
Show your flesh eaten away
Re:tar files?
« Reply #1 on: April 15, 2004, 16:40 »
Winrar and Winace do rars, tars and other compressed files have a look around for those programs  :)
Re:tar files?
« Reply #2 on: April 15, 2004, 16:44 »
i have winrar but how do i go about installing tar programs coz you open a tar file then theres about 50 more  ::)
do i extract them all to a folder?
i think i av done that b4 and it worked  :-\
Eyes of the dead
Re:tar files?
« Reply #3 on: April 15, 2004, 16:56 »
If its a multi rar or multi tar file then usually by opening the first rar or tar it will extract all the others too.
I usually make a folder and extract the lowest numbered rar or tar into it and it will then unpack the rest of them as the instructions are embedded in that first file.
I assume that its a large program or a film file ?
You may end up with a cue and a bin file at the end of the unpacking process.
Get back to us if you cant get it to work properly  :)
Re:tar files?
« Reply #4 on: April 15, 2004, 17:05 »
ok well i am not doing it til i get back to my house on monday
Eyes of the dead
