Author Topic: weird noise comming from my tower!  (Read 1951 times)
Offline Jaminxz
« on: April 15, 2004, 21:26 »
everytime i click the mouse or type on the keyboard, a hear a weird electronic scrating noise coming from my tower,anyone got any ideas of how to fix this??
by the way, did ispell weird right?>???
Offline princeofdarkness
Re:weird noise comming from my tower!
« Reply #1 on: April 15, 2004, 21:27 »
yep you spelt weird right but i dont know about the prob so you will have to wait for a techie  ;D
quot;Spirits damned to rot
Eyes of the dead
Broken glass reflections
Show your flesh eaten away
« Reply #2 on: April 15, 2004, 21:31 »
Does it make the same noise as its booting up ?
If so it could be a sign that your hard drive is on its way out  :(
« Reply #3 on: April 15, 2004, 21:35 »
how the hell can your hard drive just brake?
Eyes of the dead
« Reply #4 on: April 15, 2004, 21:36 »
on its way out? luckily i have mine screwed in.. no escaping for my hard drive  ;D
Eyes of the dead
« Reply #5 on: April 15, 2004, 21:40 »
They spin at 5400 rpm for the older drives, 7200 rpm for the newer drives, Serial ATA are now around 10500 rpm.
Wear and tear on the bearings causes the platters to wobble putting more strain on the bearings which eventually leads to a noisy drive failure.
There are also the arms which read and write to the drives, they are constantly moving across the drive and they like any mechanical device can wear out.
The electronics that control the drives operation and the drives motor itself can burn out or develop faults too.
These are just some of the ways that a drive can suddenly fail  :(
« Reply #6 on: April 15, 2004, 21:42 »
i have a 80 gig serial ata 7200 when do you think its.. time .. will come  :'(   :'(   :'(
 :aarrgh:
Eyes of the dead
« Reply #7 on: April 15, 2004, 21:43 »
All things come to an end, usually a week or two after the warranty has run out.
Thats why you should always back needed stuff up regularly  :)
« Reply #8 on: April 15, 2004, 21:43 »
o no wait i dont know if mine is serial ata.. what are the other types/type (not very technical)
Jonah
Eyes of the dead
Online Simon
« Reply #9 on: April 15, 2004, 21:45 »
I'm sure Jam will appreciate your more constructive comments, Sandra.   ;)
Jam, it would be advisable to start backing up anything you need to keep safe, in case your hard drive suddenly fails.
« Reply #10 on: April 15, 2004, 21:45 »
tell me sandra how.. how..  :'(   :'(   :'(
how.. long has it got left.. i cant just keep buying new hard drives every 10 minutes lol  ::)
Eyes of the dead
« Reply #11 on: April 15, 2004, 21:46 »
Yours will probable be an EIDE drive Jonah  :)
« Reply #12 on: April 15, 2004, 21:47 »
is that good then?
can you have an ata and an eide?
Eyes of the dead
Offline Jaminxz
« Reply #13 on: April 16, 2004, 19:27 »
it seems to have stopped now, but i will start backing my stuff up just in case!
Online Simon
« Reply #14 on: April 16, 2004, 20:12 »
Optimistically, there's a chance it could just be one of your fans on it's last legs, because they can make funny noises, but from what you've described, it sounds more likely to be the hard drive, so yes, I would start backing up.   :-\
