Author Topic: webpage done but with errors  (Read 2319 times)
Offline maria9547
« on: January 04, 2003, 21:15 »
???  Sometimes when browsing, a link doesn't work or I get a message on the bottom left of my taskbar (?) that the page is done but with errors, or javascript error. Is this me or the website?  I am running Win2000 and I. E. 6.0.  I tried to reinstall or repair Internet Explorer but still get the same results, off and on.
Re:webpage done but with errors
« Reply #1 on: January 04, 2003, 21:33 »
Hiya Maria, welcome to the zoo!  ;)
Regarding your problem, if it's only once in a while that it happens, then it's probably just a bit of dodgy coding on the site you're visiting.  If it happens a lot, with more professionally designed sites, we've got a problem.
1.  Have a look in Tools -> Internet options -> Advanced.
2.  Now look at the list of checkboxes.  Is 'Display a notification about every script error' ticked?  If it is, then untick it and you should have an easier life.   :)
Please keep us posted, because I'm making this up as I go along.   ::)
« Reply #2 on: January 04, 2003, 21:39 »
I sometimes get this behaviour when the pop-up window killer that I use (EMS Free Surfer) does its stuff.
If you don't have a pop-up killer running, it's possible that you are having connection problems.
Can you tell us a little about how you connect to the net (e.g. dial-up or ADSL, modem type etc)
Offline bat69
« Reply #3 on: January 04, 2003, 21:42 »
Hi, I'm no expert on this either, but I have had this when I've gone into the area Rodders mentioned and disabled certain Java functions for security reasons. Pages using these Java codes then show an error message.
Offline maria9547
« Reply #4 on: January 05, 2003, 16:36 »
Thanks everyone.  I looked for that box to uncheck and it was already unchecked in the Advanced section of Options.  I am connected to the internet by DSL and I do run AdSubtract for all those popups.   Like you said, maybe its the website itself.  Hope so.
Thanks again and wishing you all a HAPPY NEW YEAR!!!!!  (Well, better late than never right?)
Offline bat69
« Reply #5 on: January 05, 2003, 16:38 »
Thanks very much Maria, and the same to you ... hope its a good one for you  :-*
I wouldn't worry too much about it unless you are having big problems viewing web sites.  :)
Offline maria9547
« Reply #6 on: January 05, 2003, 16:44 »
ok,sounds good to me.
