Author Topic: Backup  (Read 1135 times)
Offline JK
Backup
« on: April 17, 2004, 23:51 »
Hi I wonder if you guys and girls can help me sort out a backup situation. When trying to do a complete PC backup is closes halfway through saying that a programe is still open and running.
I have all the programes closed except for one which I do not know how to close. This being an internal PCI DSL modem with conexant chipset. This is always running and looking for a connection. Does anyone know how to turn it off when doing a backup?
Re:Backup
« Reply #1 on: April 17, 2004, 23:57 »
You could always remove it from the device manager and then after you have backed everything up it will install it again after you reboot  :)
Re:Backup
« Reply #2 on: April 17, 2004, 23:58 »
How about going into Start > Run > MSCONFIG and temporarily disable it from the startup tab, then reboot?
Re:Backup
« Reply #3 on: April 18, 2004, 00:06 »
http://home.ptd.net/~don5408/toolbox/enditall/
May be the easiest application to use.
Re:Backup
« Reply #4 on: April 18, 2004, 00:08 »
:doh:  I've got that sitting on my taskbar, and forgot it!   ::)  Good job there's a professional about!   ;D ;D
Re:Backup
« Reply #5 on: April 18, 2004, 00:13 »
Body? Doyle?  ;)
