Author Topic: PSU POWER?  (Read 3386 times)
Offline Big_Boss
PSU POWER?
« on: January 04, 2003, 21:56 »
Soon im going to be upgrading my processor and motherboard as the one i have the now is getting a bit dated. Im thinking about this one as its a complete pack and comes with DDR memory.
http://www.komplett.co.uk/k/ki.asp?action=info&p=19803&t=1611&l=3&AvdID=1&CatID=44&GrpID=6&s=pl
But then i thought that maybe i should have a bit more and get this one.
http://www.komplett.co.uk/k/ki.asp?action=info&p=24316&t=1611&l=3&AvdID=1&CatID=44&GrpID=6&s=pl
I doesnt really matter what one i get but i think the dearer one might be better value.
Anyway what im not sure of is my case. I think the motherboards will fit fine since its an ATX case but im not sure it my PSU will be up to scracth. Its a 300W PSU. What im wondering is i am going to have to upgrade that aswell or is it fine the now?
And if you have a similar processor can you tell me what power your PSU is.
Thanks in advance,
Big_Boss
Offline bat69
Re:PSU POWER?
« Reply #1 on: January 04, 2003, 22:06 »
Hi Big_Boss
A lot depends upon what devices you will be using, the more you use the more power you need. I think 300W might just be pushing it a bit for a newer system.
Offline Big_Boss
Re:PSU POWER?
« Reply #2 on: January 04, 2003, 22:10 »
Ok thanks.
What value of PSU will i need to get then? And can i just replace the one thats there?
Big_Boss
Offline bat69
Re:PSU POWER?
« Reply #3 on: January 04, 2003, 22:21 »
It really does depend on what you are using in your system ... I would say a 350W minimum, but more wont do any harm
Yes you just unscrew the PSU, unplug all the leads, and replace the PSU and leads ...et voila  8)
Just make sure you get an ATX PSU  ;)
Offline Big_Boss
Re:PSU POWER?
« Reply #4 on: January 04, 2003, 22:23 »
And one more thing  ;D
Ive been looking at a few local shops and one in particluar is selling a 350W PSU for £30. Is this a good deal or not?
Also do you know any good sites for buying PSUs?
Thanks in advance,
Big_Boss
Offline DualBoy
    • http://www.pingme.ca
Re:PSU POWER?
« Reply #5 on: January 04, 2003, 22:25 »
What motherboard is that unit? It does not give any information on the site.
Offline bat69
Re:PSU POWER?
« Reply #6 on: January 04, 2003, 22:28 »
I'm probably getting a Qtec 550W PSU costing £35 from www.falconcomputers.co.uk   a reasonably local shop to me
Re:PSU POWER?
« Reply #7 on: January 04, 2003, 22:30 »
I've used Novatech for about three years now, and always find them extremely competetive.   :)
(The link points to their PSU page)
Offline Big_Boss
Re:PSU POWER?
« Reply #8 on: January 04, 2003, 22:34 »
Yeah that one looks good bat69. Good price too  :o :o
Will it matter if i go for that high power one or one like a 400W?
Also, i dont think they deliver  :-[
Big_Boss
Re:PSU POWER?
« Reply #9 on: January 04, 2003, 22:53 »
Thanks for the link to Komplett, Big Boss.  A friend has been looking for an upgrade bundle, and those look just the job!  Have you actually dealt with them (Komplett) before?  The only thing I would watch out for might be the quality of the fan included.  You really don't want to skimp on that, as Bat, and many others will confirm!
I'd also like to second Rodders' recommendation of Novatech.  I've been using them on & off for about a year, and never had any problems.
Offline bat69
Re:PSU POWER?
« Reply #10 on: January 04, 2003, 22:55 »
The 400W PSU hasn't fared so well in reviews and doesn't deliver the power well.
I'll look on google to see if I can find anywhere else that sells Qtec PSUs in the UK ... there's bound to be more as they're so cheap
Offline bat69
Re:PSU POWER?
« Reply #11 on: January 04, 2003, 23:07 »
Try HERE
and HERE
Offline Big_Boss
Re:PSU POWER?
« Reply #12 on: January 05, 2003, 09:59 »
Hi Simon
I havent actually bought anything from them before but they seem ok.
Thanks for the advice. I havent made my decision yet, ill have to weigh everything up.  ;)
Big_Boss
