Author Topic: cd-rw trouble!!  (Read 861 times)
Offline Jaminxz
cd-rw trouble!!
« on: April 18, 2004, 21:39 »
i've been trying to rip some data files onto cd using instant cd+dvd software, i think it's pinicle software.
when i tried this i got an error saying something like 'hardware error spindle servo failure.
after this i tried just right clicking on the data and doing send to cdrw. after i burned the cd my drive would not recognize it.
Do you think it's a problem with my drive of with the disks i'm using?
Re:cd-rw trouble!!
« Reply #1 on: April 18, 2004, 21:45 »
With that sort of error message, it would seem to me that the drive is malfunctioning, or, in technical terms...  knackered!
From Google:
Spindle Failure (HARDWARE ERROR)
"The spindle servo was not locked with the reference signal and the medium was not rotated correctly."
Of course, I could be totally wrong, so wait for a techie to come along!   ;)
Re:cd-rw trouble!!
« Reply #2 on: April 18, 2004, 21:56 »
Have a look at this page Jam.
Possible solution third post from the bottom of the thread :)
Offline Jaminxz
Re:cd-rw trouble!!
« Reply #3 on: April 19, 2004, 21:42 »
cheers guys, after reading that link i grabbed a cd-r disk from my mate (different branded one) and it worked ok, i'm getting some more disks and then i'll be able to find out for sure.
Re:cd-rw trouble!!
« Reply #4 on: April 19, 2004, 22:42 »
I think that by doing the above method it would have by passed your normal burning program and used XPs built in burning software.
I have found that sometimes its ok and sometimes not, regardless of the make of cd.
If the new cds that you get later work ok then maybe you could get your friend to try the ones that dont work on yours  :)
