Author Topic: paint shop pro  (Read 6565 times)
paint shop pro
« on: January 04, 2003, 22:14 »
I've just installed it and notice that when I right click my delete bin it says brouse paint shop pro. How can that be??
Re:paint shop pro
« Reply #1 on: January 04, 2003, 22:18 »
PSP will allow you to browse the picture files in your deleted files folder too Lona ;)
Re:paint shop pro
« Reply #2 on: January 04, 2003, 22:28 »
Who would have thought of brousing from the recycle bin. Seems odd. I have never had any other programs do anything like that. ???
Re:paint shop pro
« Reply #3 on: January 04, 2003, 22:30 »
PSP is very special Lona ;)
Offline Big_Boss
Re:paint shop pro
« Reply #4 on: January 04, 2003, 22:36 »
:D :D :D
Re:paint shop pro
« Reply #5 on: January 04, 2003, 22:50 »
I still can't enhance my photos to my liking. But then with my photos you would need more than PSP ;)
Re:paint shop pro
« Reply #6 on: January 04, 2003, 22:55 »
Which version of PSP do you have Lona?
I use version 7 which has some great photo enhancement tools under Effects | Enhance Photo ;)
Re:paint shop pro
« Reply #7 on: January 04, 2003, 23:03 »
It is version 7 but you haven't seen my photos. They are all scratched and ancient :(
Re:paint shop pro
« Reply #8 on: January 04, 2003, 23:10 »
There's an enhancement to remove scratches, Lona, but don't know how good it is.   :-";"xx
Re:paint shop pro
« Reply #9 on: January 04, 2003, 23:14 »
Have you tried the Automatic scratch removal tool Lona? It is really very good.
I have used it to retouch a few of my old black and white baby photos, which were quite heavily crumpled.
The trick is to work on small areas at a time.
Re:paint shop pro
« Reply #10 on: January 04, 2003, 23:16 »
Will I send you my photo Adept. It is 56 years old and I am not joking ;D
Re:paint shop pro
« Reply #11 on: January 04, 2003, 23:23 »
OK Lona, it would be interesting to see if I can do anything with it  :D
Re:paint shop pro
« Reply #12 on: January 04, 2003, 23:34 »
Just sent it Adept :D
Offline Whiskas
Re:paint shop pro
« Reply #13 on: January 05, 2003, 00:26 »
When I try to open anything in my psp it says  the file type of this file is unknown  ???
Re:paint shop pro
« Reply #14 on: January 05, 2003, 00:39 »
Whiskas if you open PSP there will be somewhere in the tool bar at the top for options or preferences,cant just remember which at the moment.Go in there and look for file associations and tick the ones you want ie jpg and gif plus any others that you think you may want to manipulate later  :-*
