Author Topic: bowr.exe??  (Read 790 times)
Offline jiml
bowr.exe??
« on: April 19, 2004, 16:35 »
I noticed a new .exe on my Task Manager this morning, "bowr.exe" does anyone know what this is?
Thanks
Jim
Re:bowr.exe??
« Reply #1 on: April 19, 2004, 16:44 »
If it's not something you have installed, chances are it's not supposed to be there, Jim.  However, a Google search produced absolutely nothing.  Can you confirm the spelling of it?
What you could do in the meantime is run a spyware check, with Ad Aware and / or Spybot, then install Spyware Blaster to prevent future invasions (links below).
Ad Aware
Spybot S&D
Spyware Blaster
Offline jiml
Re:bowr.exe??
« Reply #2 on: April 19, 2004, 17:31 »
Thanks Simon
I could not find anything on the web about it either. I renamed it rebooted and it did not come back. I am running Norton and SpySweeper again after I updated both to see if it finds something.
Jim
