Author Topic: HELP PLS! cannot copy and paste!!  (Read 985 times)
Offline dnf999
« on: April 24, 2004, 12:48 »
Hey guys
I can't copy and paste?!!!
Any ideas why not?? I can't copy and paste usually and
i can't using Ctrl+c and Crtl+v!!!
Please help me!  :-[
Re:HELP PLS! cannot copy and paste!!
« Reply #1 on: April 24, 2004, 13:26 »
That happened to me once but a simple re-boot solved the problem.   :)
« Reply #2 on: April 24, 2004, 20:05 »
What operating system are you using?
I have solved this problem in Windows 98SE in the past by running the System File Checker.
Offline ketamininja
« Reply #3 on: April 26, 2004, 14:59 »
Hey guys
Please help me!  :-[
Right, well if you can't do it either way - from the meun or with shortcuts, then I would have to suggest something is wrong with the clipboard! Although I'm not sure what there...
It is possible that the function has become corrupt - but I really have no idea on fixing that in XP, if thats what you have. 98 just useuse SFC.
But if that doesn't fix the solution, then there may be a program running that is somehow blocking the copy/paste functions??? Strange.
Can you see the options (in Edit menu) or are they "ghosted" as if you can't click on them?
