Author Topic: Lost Scanner Driver  (Read 1052 times)
Offline Scotty_CFC
Lost Scanner Driver
« on: April 26, 2004, 21:36 »
Hi, I deleted my scanner driver by accident. I cant find the disc or anything. I went to download.com and found nothing, i went to the cannon site which was crap, and i went to scanner-drivers.com which gave me a download that was a load of crap. The scanner is a Cannon Canosacan N1240U, O.S is XP. Any help will be appreciated, Thanks
Re:Lost Scanner Driver
« Reply #1 on: April 26, 2004, 21:49 »
http://www.driverscollection.com/?file_id=20452
Any use? Or is it the same as the previous one?
Offline Scotty_CFC
« Reply #2 on: April 26, 2004, 21:53 »
That was great, downloaded it and scanner is responding. New problem now. Usually when i press "scan". The software will automatically start up, i tried to find the software but bo good, ill continue searching for it unless u guys have any better ideas. Thanks again
« Reply #3 on: April 26, 2004, 21:55 »
Beat me to it Dack ::)
Scotty_CFC try Canon's website :)
