Author Topic: Temp Files  (Read 1764 times)
Temp Files
« on: April 27, 2004, 12:13 »
Help!!
I think I might have accidently deleted my temp file folder when doing some spring cleaning  >:(
How would I know if I have, I know it seems a stupid Question but when I look in the temp file in Windows there is a folder that is not accesible or am I looking in the wrong place  ???
Cheers Hookstar
Re:Temp Files
« Reply #1 on: April 27, 2004, 12:23 »
There are usually files in Temp which you cannot delete, but if you have managed to delete the folder it isn't a problem - Windows will just recreate it and fill it with all sorts of cr@p ;)
Re:Temp Files
« Reply #2 on: April 27, 2004, 12:29 »
So its not a big problem then Adept, how will I know where to delete all the temp files  ??? or will that happen on Auto.
Offline flame spark
Re:Temp Files
« Reply #3 on: April 27, 2004, 13:45 »
i know evry fing bout pcs  , more than all u lot  8)
Re:Temp Files
« Reply #4 on: April 27, 2004, 13:51 »
eye fink u r tallkin fru yor r's  ;D
Re:Temp Files
« Reply #5 on: April 27, 2004, 13:57 »
Thats good as its always nice to have someone around who knows everything  :)
Its must be an age thing as when I was a teenager I knew everything there was to know about everything too, or so I thought, then as I got into my mid twenties I realised that even though I knew a lot more than I did in my teens there was still so much that I didnt know.
The older you get the more knowledge you acquire but the more knowledge you get the more you realise that there is still more that you dont know than that which you do know  ::)
Its such a shame that youth is wasted on the young  ;)
Re:Temp Files
« Reply #6 on: April 27, 2004, 14:13 »
Why didn't all lifes problems come to me when I was a teenager...and I had all the answers.  ;D
Re:Temp Files
« Reply #7 on: April 27, 2004, 14:17 »
That's great Walker.  :D. Maybe somebody could teach you how to spell and then you would know even more.  ;)
Offline Michelle
    • Techieminx
Re:Temp Files
« Reply #8 on: April 27, 2004, 15:55 »
I have some room in my class room, the kids can teach you.
(like they teach me)  ;D
Re:Temp Files
« Reply #9 on: April 27, 2004, 17:43 »
I have some room in my class room, the kids can teach you.   ;D
I think Walker might feel a bit challenged in your class, Shell.  5 years olds, aren't they?  ;D
But Sandra, I thought you did know everything!   :P ;D ;D
Re:Temp Files
« Reply #10 on: April 27, 2004, 18:50 »
I know Fcuk all about computers Walker, but I have just done a repair install and hopefully repaired my computer  ;D
Updated with the Micro$oft update disk ..it works  ;) but have just scanned for the updates that have been released since the disk was sent and have over an hours worth of down loads left  ???...Ohhh hurry up BB.
Re:Temp Files
« Reply #11 on: April 27, 2004, 19:01 »
Unfortunately Simon even I dont know everything   :)
I think you have been misreading the quotes that I have above and below my sig :
"It is nice to be important but it is more important to be a nice person"
"I am never wrong, I thought I was once but I was mistaken"
Re:Temp Files
« Reply #12 on: April 27, 2004, 19:07 »
It's a pity you're not quite so gifted when it comes to spelling, Walker.  Otherwise, you might not mistake an 'n' for an 'l' when writing your name.  Hope this helps.   ;)
Offline Michelle
    • Techieminx
Re:Temp Files
« Reply #13 on: April 27, 2004, 21:44 »
:pmsl:  :-X
Re:Temp Files
« Reply #14 on: April 27, 2004, 22:50 »
well I reckon he would make a good fisher man, coz plenty took the bait.  ;D
