Author Topic: networking  (Read 1114 times)
Offline goldie7
networking
« on: April 29, 2004, 17:25 »
:-[ Hi
iam trying to network 2 computers one xp the other me , on Me when trying to open files i get the mssage \\goldie\letters is not acecessible
not enough memory is availible .quit some programs .
iam using a router & can access the web on both .
have plenty of memory .
want to use the Me computer for storage of my photos
any one got any ideas .
Goldie  :-[
Re:networking
« Reply #1 on: April 29, 2004, 17:29 »
Hi Goldie and :welcome:
Have you got the folder that you are trying to access "Shared" ?
Offline goldie7
Re:networking
« Reply #2 on: April 29, 2004, 19:27 »
Hi,
Yes my files are all shared ,
i can see them , can open from XP to ME
but not from Me TO xp
Goldie
Re:networking
« Reply #3 on: April 29, 2004, 21:12 »
Does the account you use to log on to the ME PC have a password?
XP is very fussy about who it connects to and will only speak to PCs with passwords set.
Also, make sure that the TCP/IP protocol is installed on the ME PC.
Some other suggestions can be found here.
Re:networking
« Reply #4 on: April 29, 2004, 21:33 »
Have you got a firewall on each PC ?
If so make sure that you set them to allow the others LAN IP to access it  :)
Offline goldie7
Re:networking
« Reply #5 on: April 29, 2004, 23:44 »
Thanks
but still having problems for some reason
 :(goldie
Re:networking
« Reply #6 on: April 29, 2004, 23:50 »
Are you still getting exactly the same message ie not enough memory  ???
If so then me and Adept may be thinking along the wrong lines and it could be a problem on your ME pc  :(
What are the specs for the ME pc ?
Offline goldie7
Re:networking
« Reply #7 on: April 30, 2004, 13:59 »
thanks for your help
its a AMD athlon processor 906mhz
512 mb memory 25% utilized 36.29 gb hard disk used 5.75 gb
win me 4.90 build
windows memory free 2028 mb  used 72.2 mb
 :( I just want to be able to use it for storeing &  my digital photos .
Goldie
