Author Topic: Weird problem Very wierd!!!  (Read 1372 times)
Offline gandofini
« on: April 29, 2004, 17:43 »
Ok here it is lads "Excuse my spelling first fo all Dislexik"
When in windows using chat rooms mirc web browsing all of the normall things my Keyboard works fine.When i join a game like Cod Cs or rainbow six my keyboard stops working,Not all of it keys that work are.Caps locl cntrl alt Arrow keys delete page up page down.but in windows it works proberly ive updated windows drivers uninstalled keyboard,reinstalled etc,virus scanned,tried a new keyboard.Im running thin on things to try also i cant system restore :/ Any help would be great.Because atm my pc is on its way out the window,ive been shouted at form my old dear for claling it a f***ing spastic already cheers chow!!
Re:Weird problem Very wierd!!!
« Reply #1 on: April 29, 2004, 17:57 »
Hi Gandofini and :welcome:
It sounds more like the games issue rather than your keyboard itself or windows.
I dont know the games that you mention are they on line ones or ones that you run from cd/dvd  ???
Offline gandofini
« Reply #2 on: April 29, 2004, 18:02 »
The games are online just started to happen yesterday might of f***ed something when i was drunk but id like to get it sorted.Agravating pc's are
Offline Michelle
    • Techieminx
« Reply #3 on: April 30, 2004, 13:01 »
Did you know the swear filter 8) doesn't work in "search new"  :o   ;D
« Reply #4 on: April 30, 2004, 13:09 »
Shhhhh!  :adept:
Offline ketamininja
« Reply #5 on: April 30, 2004, 18:09 »
Hi Gandofini.
You said this has only started to happen.
The keyboard is an input device, and should not really have problems like this - if it's working in Windows, it should work anywhere. But it's obviously not.
I would suggest that the key mapping in your games has been lost - ie "walk forward" or "change weapon" does not have a key assigned to it. This can occur if the CFG file that contains all the key mapping has been deleted or modified incorrectly.
Thats somewhere to start, but if you want to try a usually foolproof solution, uninstall a game, then reinstall.
Offline gandofini
« Reply #6 on: April 30, 2004, 19:46 »
well people i bought a new keyboard logitech usb,The problem still persists.Ive tried to fix my cfg but it dont work m8 same problem and how can all of my games have the same problem it cant buddie,there is somehting wrong with pc and i aint got a clue nor does any one else on the net :/
« Reply #7 on: April 30, 2004, 20:22 »
This is just a wild stab in the dark, as no one else has come up with anything, but could this be anything to do with Direct X?  I'm just trying to think of things which might only affect games.   :-\
Offline gandofini
« Reply #8 on: April 30, 2004, 21:04 »
ok after some grueling game research this is only affecting my online games ofline games dont get this problem~!
« Reply #9 on: May 01, 2004, 08:35 »
Usb modem/broadband perchance - as well as usb keyboard?
I'd try putting one of the USB adaptors on the keyboard and plugging it into the PS/2 port and seeing what happens.
(You might be maxing out the bandwidth, power etc. on the USB port)
