Author Topic: USB, which do i need male or female  (Read 838 times)
Offline geordie77
« on: April 29, 2004, 23:12 »
I have a bluetooth mobile and also a palm Tungsten E.  The palm does not have bluetooth and as it is a tungsten E the only port it has is a small usb port. I have purchased a bluetooth dongle but fits a normal USB.  I am looking on the net for an adapter to convert the USB to the small USB but i am unsure if I want female to male?
No idea what male and female means in computer terms.
Thanks to anyone who can help.
Re:USB, which do i need male or female
« Reply #1 on: April 30, 2004, 00:34 »
Technically speaking it's quite easy to remember which are male and which are female.
Male plugs stick into things while the female plugs accept things :)
For a size adaptor you would need a female socket on one end (to accept the male plug) and then a smaller male plug on the other side - to stick into the appliance.
Offline ketamininja
« Reply #2 on: April 30, 2004, 19:34 »
my "female" doesn't accept anything unless a card and an apology is issued first.  :o
« Reply #3 on: April 30, 2004, 19:36 »
Quite right too  :P
Didnt you know that its written in the code of "How to treat menfolk" K, and passed down from mother to daughter for millenia  :)
