Author Topic: Pop up Problems  (Read 994 times)
Offline steved
  • New Registration
Pop up Problems
« on: May 10, 2004, 00:15 »
Hi all, This is the first time I have used his forum and hopefully someone out there can help me.
 I seem to have loaded some sort of adware on my PC at some point.. what it does is it minimizes whatever I am doing and pops up an advert using internet explorer.
I have installed panicwares free version of spybot search and destroy which found some adware software and I deleted it all but it didn?t stop this. I also installed their popup stopper which stops the popup window opening but not from it minimizing whatever I am doing which most of the time is playing online games, and having Medal of Honor minimize back to your desktop every ten minuets during a game is driving me mad!! ???
I would be most grateful of any advice
Thanks in advance Steve
Re:Pop up Problems
« Reply #1 on: May 10, 2004, 00:34 »
Hi Steve and :welcome:
I find Adaware to be very good, a lot of the people on here use that and Spybot as one often finds something that the other misses  :)
Its available free from :
http://www.lavasoftusa.com/
Another program to try if that doesnt work is "Hijack This", I will see if I can find a link for you for that if adaware doesnt sort it for you  :)
Also its sometimes better to run a scan in safe mode with the ssytem restore turned off, if you are using XP or ME as stuff can lurk in the system restore and reactivate itself  :(
Re:Pop up Problems
« Reply #2 on: May 10, 2004, 07:48 »
Here are some links you may find useful:
Ad Aware
Spybot S&D
Spyware Blaster
Hijack This
Offline steved
  • New Registration
Re:Pop up Problems
« Reply #3 on: May 10, 2004, 22:32 »
;D Awesome !! ;D
 I ran adaware in safe mode and it found 86 things to delete
I played Medal of Honor for an hour no problems
Thanks for your replys.. you helped me loads
Steve
Re:Pop up Problems
« Reply #4 on: May 10, 2004, 22:56 »
Glad you got it sorted, Steve.  Thanks for letting us know.   :)
